- Bruce
- Jun 19, 2021
- 4
- 9,041
- 16,384
- Coastal Texas
- 2022 F150 KingRanch Powerboost
I do not believe that you lost a cylinder as a result of the exhaust heat exchanger leaking. If your truck actually has a coolant leak and it was severe enough to cause overheating, you would have seen dash warnings and at some point the truck would derate its power output in order to protect the motor from overheating damage. That process isn't something hidden within a simple check engine light.Maybe I’m asking the wrong question here, but just curious to try and make sure things are fixed correctly on my truck because it seems my dealership doesn’t care to find out the actual cause of my issue. About 3 weeks ago I got a flashing check engine light in my 2021 Powerboost. Truck was suddenly running really rough. Slowly drove it to nearest dealership and it’s been there since. The dealership is saying that the number 2 cylinder is shot. Apparently the spark plug was bent when they looked at it. They are ordering a long block for the truck and just started putting it in today. Throughout the process I’ve been asking for a root cause of why this happened, as the truck only has 9,000 miles on it. The dealership is telling me that they won’t know, they can’t know, and they won’t look any further into the cause, but will fix the damage and make sure the truck runs. They’ve said it could be that something overheated, but that’s as far as they will go. I never got any overheating lights or warnings, and heard the fan loudly running a few times, but never anything concerning. I didn’t check coolant levels at all, as I never got warning lights for overheating, and was more concerned about getting the truck to a dealership when this all happened. But, my question is….could the issue this thread is about have caused the engine to overheat, or been running hotter than it should have been, causing the damage to the engine? I don’t know enough about engines to answer on my own, but clearly my dealership isn’t going to answer it, and I don’t want to have engines replaced every 9,000 miles. Thanks!
I've been around the 3.5 Ecoboost since it's inception in the 2011/2012 F150. Although these Gen3 3.5 Ecoboost are substantially refined compared to the original Gen1, they still are capable of suffering a catastrophic cylinder failure as a result of a factory defect with one of the combustion chamber components.
The pistons are still nothing that would impress a motor builder, considering they are cheap built-to-cost cast pistons for a motor making 100+HP per liter. Losing a piece of piston skirt is not rare in these motors. Or a bad injector could quickly ruin a cylinder in multiple ways.
Obviously nobody can provide a trustworthy internet diagnosis from your single post, but I personally don't believe a leaking exhaust heat exchanger is the reason you are getting a new longblock.
Regardless of the real cause, I would at least like to see Ford provide you with the equivalent of a Ford ESP extended warranty in order to alleviate the concern that you might have in the back of your mind.
