i am surprised at the last 4 now that have occurred in last 3 weeksStill on 3.5.2. 3.5.3 is partially loaded. I just have to be patient........
Maybe if I stop thinking about it, it will finish the update
Nice. I haven’t driven my truck in about a week but based on yours and others’ experience, I’m expecting to see the second update come through when I’m in it today or tomorrow.got the 22-PU1010-MIL-QL on 2/11 and just got the 22-PU1010-MIL-LT on 3/1
so i have automatic updates on. i also had it set for 21:30 last i checked. Not sure if its still set for that. I know the last few updates happened while i was at work. So NOT at 21:30 hahaNice. I haven’t driven my truck in about a week, but based on yours and others’ experience I’m expecting to see the second update come through when I’m in it today or tomorrow.
My drives are usually 25-30 minutes each way, wherever I’m going. For each of the previous ones in February, they happened in those windows. The LTE service at my house isn’t outstanding. Waking up the truck and going for a drive seems to trigger it, presumably where there’s better coverage.so i have automatic updates on. i also had it set for 21:30 last i checked. Not sure if its still set for that. I know the last few updates happened while i was at work. So NOT at 21:30 haha
I also drive my truck M-F for about 35-40min to and from work. Cell service for At&T is ok as half my driving is out in the sticks. so yeah, seems as if my updates have been pretty steady as of late.
I don't think so, but I am not 100% sure.I JUST got my truck 100% working correctly again by adjusting things in several modules. Do these Ford updates mess up things you used Forscan to fix? (had to recalibrate ride height sensors in VDM to make scales work, updated BCM for new tire size, reinitialized the PCM, etc.)
An OTA update will at times reload and or change "as built" information from the Ford cloud to enable features in the new software. Depending on when you made these Forscan changes, your trucks "as built" information may not have yet propagated itself to the Ford cloud servers and because of this your changes were overwritten. It usually takes a month to a month and a half to for the truck to sync up with Ford cloud after you've made changes with Forscan.I JUST got my truck 100% working correctly again by adjusting things in several modules. Do these Ford updates mess up things you used Forscan to fix? (had to recalibrate ride height sensors in VDM to make scales work, updated BCM for new tire size, reinitialized the PCM, etc.)
Good info, thank you.An OTA update will at times reload and or change "as built" information from the Ford cloud to enable features in the new software. Depending on when you made these Forscan changes, your trucks "as built" information may not have yet propagated itself to the Ford cloud servers and because of this your changes were overwritten. It usually takes a month to a month and a half to for the truck to sync up with Ford cloud after you've made changes with Forscan.
As expected, LT came through as soon as I started driving tonight.My drives are usually 25-30 minutes each way, wherever I’m going. For each of the previous ones in February, they happened in those windows. The LTE service at my house isn’t outstanding. Waking up the truck and going for a drive seems to trigger it, presumably where there’s better coverage.
Feb 3 - 3.5.3.2
Feb 7 - 3.5.4
Feb 9 - 22-PU1010-MIL-QL
I’ll post if I receive LT today as well.
So I am confused I have just gotten updated to 3.5.4 and now I am gettign OTA 22-PU1009 but it has failed to install. Should I cancel it or let it keep trying to install ? my vin 1FTFW1ED3MFB23739Amen to that!
The 21 J1's are finally doing what they should have done from the beginning.
If 3.5.4 installed ok, you'll probably be getting 1007, and 1010 shortly as well as 1009, give it a chance 1009 should retry, again and hopefully it will install successfully.So I am confused I have just gotten updated to 3.5.4 and now I am gettign OTA 22-PU1009 but it has failed to install. Should I cancel it or let it keep trying to install ? my vin 1FTFW1ED3MFB23739
Mobile version of PTS isn't letting me see anything for whatever reason, but yes, I'd try again.So I am confused I have just gotten updated to 3.5.4 and now I am gettign OTA 22-PU1009 but it has failed to install. Should I cancel it or let it keep trying to install ? my vin 1FTFW1ED3MFB23739
thanks for trying to check. it is scheduled to update again at 3am. it has failed three times now. ... if you find anything please let me knowMobile version of PTS isn't letting me see anything for whatever reason, but yes, I'd try again.
