Calson
- Jul 16, 2022
- 27
- 1,285
- 637
- Monterey CA
- 2022 F-150
This problem is only with the max payload package where the trucks have a different 9.75-inch 3/4-floating rear axle.
The bolts are shearing as they were either over torqued on the assembly line or they were not properly hardened by the bolt manufacturer. If the bolts are defective then replacing them with bolts from Ford is not likely to be a solution. Only if they were over torqued by the factory would replacing them before they fail would be worthwhile.
Either way it is an accident waiting to happen and Ford has decided not to issue a TSB much less a recall of the trucks.
The trucks are definitely not safe for towing when a rear wheel can fall off with no warning and result in a jackknife with the resulting injury and possible deaths of the driver and passengers.
