Manufacturer of f150 transmission?
SumGuy
Jul 21, 2021
483
382
USA
F150 (perpetually on order)
Drugs
Ford used to build a ZF transmission, but I cannot find what transmission ford is using in the current f150s. Anyone know?
I assume it is shared with the navigator, explorer, and others as well.
Geo
Geo
Apr 10, 2021
193
121
Oregon
2021 F-150, 4x4, Lariat 501A pk. 5.0 V-8, Max Tow.
I read a towing review on Ford, GM, and Ram half ton trucks. The author said the current 10 speed transmission was a joint venture with GM and Ford. Each company has their own programming.
SumGuy
SumGuy
Jul 21, 2021
483
382
USA
Drugs
After some random digging, and a year later, appears ZF still makes the transmission for ford - however, it is apparently manufactured in Mexico now vs USA.
dolsen
Aug 19, 2022
2,078
1,898
KY
2022 Rapid Red 701A
The explorer/aviator uses a 10R60, the F150, exp/nav, and mustang use the 10R80 and the SD’s use a 10R140. I *assume* they’re all made by the same manufacturer, but they are not the same transmissions.
I’m fairly certain the gear ratios vary from model to model, even between the exp/nav, F150 and mustang.
That’s not directly related to your question, but is relevant to the first post
Buyer2021
Feb 9, 2021
1,657
2,867
TX
retired!
While R&D for for some Ford tranny's is shared with other companies I believe you'll find that the actual manufacturing of all 10Rxxx transmissions used in Ford vehicles is done in-house at either the Ford Livonia (Michigan) Transmission Plant or the Ford Sharonville (Ohio) transmission Plant.
This Ford Corporate webpage has info on all of Ford's worldwide transmission plants and the versions that each produces.
