erixgix
Folks have covered the aggressive driving angle / tow angle pretty well. The other big factor i’ve noticed is your mileage can really dive with particular speed / load combinations no matter how gently you drive even with help from the electric drive.
I was seeing some unexpected numbers and starting driving with the instant mpg meter on over a combination of rural roads and city driving. all done gingerly, no cargo.
There seemed to be a correlation with higher gear low speed lugging as it cut in and out of electric that saw the meter hanging close to 10-12 mpg while barely touching throttle to maintain 35-40 mph in 8th gear. Same driving habit around 60 mph see the meter hang around 26 - 30 mpg as it cuts in and out of electric in 10th. Tells me you don’t need to drive aggressively for it to swill gas and lugging may get high fuel demand an spool the turbos more so than more ‘purposeful’ driving at higher speeds.
Getting stuck behind someone on a 35 mph backroad mostly on trailing throttle seemed to be the worst case scenario for me.
In the end, I think it’s really hard for folks to compare numbers, too many environmental variables and conditions that can’t need accounted for. Those reports of avg 26 mpg may be largely be attributable to certain goldilocks driving conditions on top of gentle driving habits.
