hotrodmex
Pucks move the stock travel relative to the body, but you don't lose anything PROVIDED you stay within the limits of the suspension. For 21+ F150, I think that's only about 1.5" or so. BDS is adamant their 2" level does not max out any part of the suspension. This kit is a 1.5" strut spacer, and .5" spring preload. The -2020 was a full 2" of spacer ,and that jives with the change in motion ratio from 2020 to 21+.I assume this is the result of loosing some 2" of "droop". Upper control arm is over extended with both a puck and coilovers like fox, bilstein, icon, etc...
Coilovers that are stock length and lift with spring pre-load move droop travel to up travel. They have to. If total suspension travel doesn't change, but at rest the suspension is sitting 2" higher in ride height, that doesn't come from nowhere. Droop ends in same location as stock, but much less travel to get there, as it has to stop 2" sooner on its way up.
