NavyChief
NavyChief
Aug 24, 2022
204
272
Orlando, FL
21 F150
See attached pinouts for the 110 on the back. I'll look for where is goes from there. Assuming you dont have a inverter?
No I don’t have it. I’m actually thinking to mount a 1k inverter wired with its own wiring and solder in wiring on the backside of the console outlet to plug in to the inverter inside the console.
I’ve been working on a tailgate project to have a self contained power source inside the gate similar to the power center in the bed.
NavyChief
NavyChief
Aug 24, 2022
204
272
Orlando, FL
21 F150
Huge shout out to Jesse as I was looking to route the supplied XM ant he was like open your glove box and take it out real quick and sure enough I had the factory XM ant wiring already there (I was a XM delete truck) I just needed to order an adapter off Amazon to connect.
oh and having 4 cup holders vs 2 is a game changer plus because I don’t have a console shifter I can leave the work surface deployed and use the rear two cup holders while I’m working
KTM753
Oct 3, 2022
224
187
Iowa
2021 F-150 XL
Awesome thread, thanks for posting. Ballpark amount to do the conversion?
Rockman5159
Rocky
Nov 19, 2021
672
396
Marion SC
2021 ford f150 FX4
Ordered the 12” screen kit from infotainment and a console off eBay that had the work surface and got to tearing everything down.
Overall not too difficult to accomplish. I had the XM/Nav delete option so I had to order a new APIM as well.
I ordered some stuff from my dealer to complete the install.
Big shoutout for making such a complete kit infotainment :)
Couple of things to note:
The brackets that hold the center jump seat are the same as the console so don’t order new ones. You will need 4 more of the 10mm bolts to bolt the console as the jump seat has larger bolts holding it down.
Make sure you tell them when your ordering the infotainment package that you have a console as they sent me the lower for a jump seat. Also I did not need the tablet to program any codes as it turned on and worked with everything so I’m going to cancel that as they were back ordered anyway.
This is a very expensive conversion so be prepared to spend some money. To me getting a console and XM was worth it.
I’ve got some trim and the console cover that don’t match but I’m eventually having leather put in so will change it at that time but it doesn’t look too bad.
Also I’ll have to figure out the wiring in the console as it had way more stuff than I had plugs for, I just plugged in the front USB for now.
Nice job! looksreally good
nvabill
Dec 26, 2020
284
236
Virginia Beach, Va.
2022 F-150 XLT, Jeep Wrangler Rubicon
Make sure you can still start the truck if your key fob battery goes dead. The console I bought did not have the feature as it had come from a truck that had a keyed start in lieu of a push button. I ended up having to take the antenna out of the jump seat and rewiring it into the console. Either way if you don't plug the console in you will not have this feature.
4,562
4,696
If you need ANYTHING reach out to me...
Have you looked into getting the low-power BT module that the mach e and lightning use to incorporate PAAK (phone as key) by chance?
NavyChief
NavyChief
Aug 24, 2022
204
272
Orlando, FL
21 F150
All in I’m aboUt 5k in this interior project but I’m not done. Still have seats and some color matching to do plus I want the paddle shift steering wheel, push button start and passive entry at some point.
I have a standard keyed start so that shouldn’t be an issue. I know the passive att is in the console though as I saw it under the cup holders.
nvabill
Dec 26, 2020
284
236
Virginia Beach, Va.
Yep, you should be good to go then.
Charlieben
Jun 15, 2021
41
57
10536
2021 F150, 1991 Mustang, 1969 Corvette
Chief, Do you know if this would fit if just the jump seat was removed. I have a 2021 RCSB XL .Thanks
NavyChief
NavyChief
Aug 24, 2022
204
272
Orlando, FL
21 F150
Yes it’s just removing the jump seat and reusing the brackets. You will need the 4 bolts that attach the console to the brackets and the console version of the hvac panel
Heathen
Oct 27, 2022
111
78
Lowcountry
22 XLT
Hey Jeff, so my new truck is also Nav/XM delete. How hard would it be for me to add XM? Don’t really care about nav. Thanks for any info.
NavyChief
NavyChief
Aug 24, 2022
204
272
Orlando, FL
21 F150
I bought a module from infotainment that came with everything in a module that replaced the one in the center of the dash. I wanted it with the factory antenna and my truck already had the wiring so I just installed the factory antenna.
Heathen
Oct 27, 2022
111
78
Lowcountry
22 XLT
10-4, Thanks Chief.
Wallyo
Walter
Jan 11, 2023
126
46
Boise Idaho
2022 F150 Super Crew XLT
Looks great love the look in a single cab gives it a very sporty, coupe, look!
The work surface is the best thing since slice bread, actually you could not slice bread in the truck with out it!
I also have the XM delete on my 2022, was less worried about the Xm (thought there be a work around at some point) and more about wanting the work surface (currently a 195 add on in xlt trim). But now I am trying to figure out how to restore the XM. You mentioned above that you replaced the APIM. Question I have is did you have to replace both the APIM and the ACM in order to restore the XM?
The ACM in my truck does have a yellow XM jack on it and it does have XM. I have the antenna cable ending right side of glove box and starting rear right above seatbelt, nothing plugged into it.
But you were going from the 8'" to 12" screen which I already have。
Just trying to figure out what else is needed besides the XM roof antenna and a jumper Antenna cable from glove box to ? directly into the ACM? Do you have a link to the cable you used?
I be grateful for any help on this?
Wallyo
