Mosey
Hi all,
I finally installed my Boost Auto Qi charging pad that Santa brought me. The pad replaces the rubber mat in the forward-most center console tray. Installation is a bit painful as you have to remove several pieces of trim and unbolt and slide back the center console. The charging pad takes a standard 12-volt input so you do not lose one of your USB ports. I ran the positive and ground wires back to the fuse box and used a fuse tap on a switched circuit.
