m_bt54
- Bryan
- Nov 16, 2022
- 7
- 572
- 645
- Massachusetts
- 2021 F150 Lariat Powerboost Hybrid
- Occupation
- IT Director
Thanks, I’ll get out there today and re-check everything and definitely change the 3 back to 4 in the SCCMthis is what i used for glare free
i am sure you double checked it. 4 works for me in the sccm
your icons are ODD in the IP. glare free turns off the blue icon, unless you cycle the cycle the stalk
sometimes turning off truck will not clear your last cycle
wish i was closer as well to help if i could
do you have any DTCS showing up?
Here are the changes required for Glare Free headlights. There are multiple modules that need to be changed so it’s not the easiest mod.
Glare Free Menu (replaces Auto High beam) in APIM:
APIM
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
Note: a module reset in FORScan or power cycle is required for the menu to appear.
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
Perform one of the below in HCM depending on the specs of your truck:
Short bed No onboard scales / ccd
734-01-04 xx53 4E
Short bed with scales / ccd or Raptor
734-01-04 xx56 D1
Long bed no scales / ccd
734-01-04 xxD9 88
Long bed with scales / ccd
734-01-04 xxDC 17
