I think the GMT-800 stepsides were fiberglass as well.2003 stepsides used to be I know. I don't think the floor was though.
Yep. Pretty sure new Tacoma's and Tundra's have composite beds.Depending on the end use, fiberglass, or some sort of composite isn’t that much worse than aluminum alloy or steel as a bed material.
I am sure many were upset when wood beds (a sort of composite) were replaced by steel!
Tacoma has been compression molded fiberglass reinforced plastic (composite) for the past 18 years. New Tundra uses a similar fiberglass reinforced plastic (composite) today.Yep. Pretty sure new Tacoma's and Tundra's have composite beds.
No idea what you were seeing....maybe a drop in liner or reinforced spray-in. The F150 floor and inner walls are aluminum.Saw a video of a wreck this morning on the local news involving a very late model F150 and the bed appeared to be 100% fiberglass. I never knew that to be the case. I can't believe any maker would do that.
I know what damaged fiberglass looks like and it was fiberglass. It was a side view only not a top view. Bottom line is I was not aware any portion of the beds (sides) were anything other than a metal of some sort. I don't like the idea simply because of the huge difference in repairing a dent versus replacing the part regardless of the weight factor.No idea what you were seeing....maybe a drop in liner or reinforced spray-in. The F150 floor and inner walls are aluminum.
Regardless...keep in mind that 100% fiberglass would just be a pile of strings or fibers that are about as strong as a pile of grass clippings. People talk about boats and Corvette body panels being "fiberglass". They are really fiberglass reinforced composites. The glass might be chopped, strands or woven mat....but it is just the reinforcement in the mix of fiber, resin, fillers and other additives for color or fire resistance, etc.
I would like to see that picture. I can only guess it was a liner, toolbox, tonneau, topper, one of the underbody shields (some are fiberglass reinforced), part of another vehicle, or something other than the bed floor, bed walls or exterior bodysides.I know what damaged fiberglass looks like and it was fiberglass. It was a side view only not a top view. Bottom line is I was not aware any portion of the beds (sides) were anything other than a metal of some sort. I don't like the idea simply because of the huge difference in repairing a dent versus replacing the part regardless of the weight factor.
You guess wrong. It was the entire bed side exterior, not the floor like T-boned. No pic as it was on TV.I would like to see that picture. I can o ly guess it was a liner, toolbox, tonneau, topper or something other than the bed floor, bed walls or exterior bodysides.
I am not just guessing about the bed structure. Ive been involved in automotive composites for over 35 years including many Ford vehicles. The Lightning has a composite floor/ tub/liner in the FRUNK but I'll assume you know the front from the back.
