Cheez_Greater
- Jason
- Jun 1, 2022
- 1
- 85
- 72
- Washington
- 2021 F-150 Lariat
- Occupation
- BI Developer
Just a random FDRS tip that I learned. Sometimes after an update when the module is going through it's configuration step, the process will fail and FDRS will ask if you want to try again. At that point check your internet connection. Interrupted internet caused that failure for me.
I also learned not to panic. The ABS module update failed and the truck went dark (I panicked). Just be patient and everything will likely come back. It did for me. Also, follow the steps in Bob_Mac's document. The VIN didn't populate during the Vehicle Check test but everything looked okay in FDRS so I continued. After the failure I went back to the Vehicle Test and disconnected and reconnected until I got the VIN. I don't know if that was the cause of the issue but I wanted to be sure.
