Suns_PSD
- #16
21-23 F150 3.5L PowerBoost aFe Momentum GT Pro Dry S Intake 50-70099D (stage3motorsports.com)Where is it on sale?lol
$401 and free shipping (but sales tax)
saying they have 0 in stock. Did they run out since you bought?21-23 F150 3.5L PowerBoost aFe Momentum GT Pro Dry S Intake 50-70099D (stage3motorsports.com)
I ordered directly from AFE 2 weeks ago and they told me there was a 12 week backorder. I canceled my order...I suspect they were selling stock they don't keep on the shelf, which is fine by me.
Yes this is generally the case with aftermarket filter makers. The idea is that stock is most restrictive. Next least restrictive is aftermarket dry, least restrictive of all is aftermarket wet. But then the wet ones need to be oiled so the oil will allow you the supposed benefits of lowest level of restrictiveness while catching the extra debris large enough to cause long term damage that they permit through compared to dry.The dry filter is more restrictive?
I didn't know they were piping in fake noise on the PB?? Let alone an option to defeat it. I don't recall seeing anything on my screens. But maybe for higher trim levels?It’s on my list but managed to hold off.
in for your review. I am thinking we can turn off engine noise using FORScan if we want less noise. As long as it’s not too loud during casual driving it should still be ok for me
I'm not totally familiar with this platform and the potential gains of each item separately, then in combination. I doubt few are.I started with a Roush but I am replacing it with an AFE Momentum....why have a plastic aftermarket intake that's slightly less good? I also have a Cervini intake hood, and mating that into the intake is a challenge. I can't hear it until the turbos kick in.
You're not going to get any extra performance without ALL of CAI, bigger intercooler, better pipes AND high flow exhaust (which is mostly high flow cats) AND THEN getting a tune. You also need to a clear path for airflow to reach the intercooler, which means moving Ford's stupid license plate bracket and tuning the shutters so that they actually open. A CAI and a cat-back exhaust alone are a waste of money if you are going for performance, but they will sound cool. Thus far the pipes between the intercooler and the exhaust are my last two items remaining. At that point, I am waiting for the powertrain warranty to end at which point I'll do a custom tune from either Late Model Racecraft or Livernois.....I think LMR is quite pricey, but they are local and can respond more effectively to the weird stuff that I want (less power, more reliability, clean up shifts, and maybe an E85 tune). I will keep sharing what I'm doing on both forums, and when I've actually got the whole list complete in 2-3 years, I'll post the dyno results.
1) Yes, you only really get gains from a lone intercooler upgrade in avoiding heat soak. As far as flow restriction being an issue, at some level it has to be, though there are a lot of factors which make simple observation tough. First, as a thought experiment, why not just delete the intercooler (or save money and complexity by piping the turbo outlet straight into the intake manifold)? It clearly has a function, and to do its job it must have both fluids (charge air and cooling air) flowing through it. The wild card is the shutter, which is closed most of the time anyway (i.e. Ford engineered in an intercooler and functionally deletes it from the circuit most of the time by blocking cooling airflow using a shutter). So stock you have 3 obstacles to performance: stuff accidentally blocking the cooling air, a shutter deliberately blocking the cooling air and a small intercooler. My point, here and more broadly, is that you really have to address the entire chain to reap benefits, while you might get any tiny amount out of upgrading a single piece.I'm not totally familiar with this platform and the potential gains of each item separately, then in combination. I doubt few are.
That said, it would be surprising if Ford managed to create identical restriction profiles for all of these items given the different requirements such as packaging/ cost/ reliability/ sound/ emissions/ warranty/ etc. for each of the components that you listed.
A few things I can speak with some confidence on are:
1) Livernois states that their CAC doesn't alter hp at all, on the first pull. It's only when heat soaked that power drops dramatically from the heat rejection limitations from the OEM CAC. So it's not a restriction issue in this case. I didn't buy the aftermarket CAC simply because mine isn't a race truck, in fact I hardly tow these days. So, 1 good pull up to freeway speeds every 10 miles is plenty enough for my purposes.
2) My personal experience is that stock airboxes are designed around some very specific parameters that include: selling replacement panel filters, reduction in any intake/ turbo noise, absolutely preventing any water ingestion at any cost to air flow. As such, I've yet to operate a vehicle, even new ones, that don't respond positively to just a well-made CAI. Twin turboed vehicles, even more so. Now it might not be a bunch of power, but the improvement in response is nearly always instantly detectable but also a reasonable gain considering the very low risk, the low cost & how easily reversible it is. Heck, you can even resell them when done with the truck and get at least half of your money back.
3) Regarding exhaust systems: Unfortunately, direct flow through mufflers equates directly to increased hp, and it's very noticeable on the dyno, even on the butt dyno. On my Corvette, just a free-flowing cat back improved power about 38 rwhp in the midrange. Sadly, this always includes large noise level increases, and at this advanced age just isn't worth it to me any longer. That's power I can do without. There is a reason that fast race vehicles are always loud. It's not coincidence.
YMMV
