mdmeints
You are correct, I am referring to the prior years that had the SAE SN or earlier oil specs.The recommended oil in the owners manual is a SP specifiction.
I originally was concerned and did research. After I found that ford has modified its engines with an additional fuel injector before the valve, that solves the carbon build up issue and no need for catch can. These additional injectors spray fuel on top of the valves to help eliminate carbon build up. My 2 cents, for what it’s worth.Anybody install one on a power boost and where did you mount it? Looks like power boost system takes spot of normal mounting area.
...and as far the any build up on the intake ... just have let the turbo live a little once in a while.I don’t do *anything* to the engines of my late model cars. They are so tuned and set from the factory I think it’s a risk. No chips, no catch cans, nothing.
they call that an "Italian tune up" LOL...and as far the any build up on the intake ... just have let the turbo live a little once in a while.
I‘ve read that you’re not supposed to use fuel injector cleaners with ecoboost engines as they can damage the turbos. I would just stick with top tier fuel.I also add a fuel injector cleaner every few thousand miles, so hopefully that will help.
What’s your logic behind this? The ecoboost’s are pushing more boost than a gt500 in stock form. So in theory higher cylinder pressures would increase blow by.No catch can for this engine. Yes to my supercharged GT500.
Because the oil gets dumped into the supercharger and it becomes the catchcan.What’s your logic behind this? The ecoboost’s are pushing more boost than a gt500 in stock form. So in theory higher cylinder pressures would increase blow by.
My grandfather always told me to "Blow the cobwebs out of it every once in awhile"....and as far the any build up on the intake ... just have let the turbo live a little once in a while.
