Its unacceptable low quality.... It will fill with organic substances, rot and deteriorate the seal between the windshield and aluminum body. It will leak for sure.... Every single truck we've had has trim over the gap. This is what Ford charges $50k+ for? Trash...Just curious, other than dirt building up, what is the issue with the gap? Personally, I like not having the seal there as I don't need to worry about accidentally hitting it when scraping frost/ice/snow. And there's no way I can see in the gap without a ladder, so it's not like I'm seeing anything there anyway.
Not sure where you live. But if water were to get in there and not flow out the sides because of dirt buildup and the water expanded and cracked the windshield or even expanded enough to break the seal it could be a big problem.Just curious, other than dirt building up, what is the issue with the gap?
Enjoy!Thanks for the answer this is what I was afraid of.... This is unacceptable. This is worse quality then the Chinese trucks we had in China. Definitely dumping this paper mache tin foil pile as soon as the 24 Tacoma is out.
Exactly! And with the angle of the windshield the water will pool right in the middle!Not sure where you live. But if water were to get in there and not flow out the sides because of dirt buildup and the water expanded and cracked the windshield or even expanded enough to break the seal it could be a big problem.
I've seen frozen water do some remarkable things on heads and blocks.
Man, are you gonna be disappointed to see Toyota does it the same way, along with basically everyone else.Thanks for the answer this is what I was afraid of.... This is unacceptable. This is worse quality then the Chinese trucks we had in China. Definitely dumping this paper mache tin foil pile as soon as the 24 Tacoma is out.
They've been doing this since 2015 with this windshield shape. Ever heard of an issue?Not sure where you live. But if water were to get in there and not flow out the sides because of dirt buildup and the water expanded and cracked the windshield or even expanded enough to break the seal it could be a big problem.
I had a 2015 Platty and never seen that build up before, but it does snow\freeze often where I live...They've been doing this since 2015 with this windshield shape. Ever heard of an issue?
There’s a lot of places for dirt to collect on a vehicle. This one is fairly accessible. Scrub it out when you wash your truck. If the new installation technique (which is allegedly where all manufactures are going) bothers you, why not mask it off and put some black silicone in it. That would take all of 10 minutes. But im guessing by your hyperbole you’d rather just be pissed off about something. Now go ahead and let me have it, I can take it.Its unacceptable low quality.... It will fill with organic substances, rot and deteriorate the seal between the windshield and aluminum body. It will leak for sure.... Every single truck we've had has trim over the gap. This is what Ford charges $50k+ for? Trash...
