fireonice02
Jan 28, 2022
NC
2021 F-150 Lariat
Those Icon uca’s are sexy looking! I wanted to do my uca when I had the kit installed but installer said wasn’t needed with just a level. I did go with the larger SPC cam bolts.
TexasTruck
Scott
Oct 16, 2022
700
514
2022 Ford F-150 STX BAP
I fix software bugs!
One thing about the SPC CAM kits, when you take it to have it aligned, make sure the shop has 27mm deep and short sockets. I caught my local Goodyear shop trying to use a crescent wrench on mine! They need to be 198 lb/ft.
A_carrillo08
Adolf
Jan 27, 2023
Tx
Install complete! Added 275/65R20 Recon Grapplers in SL, Ford Performance Bilstein kit set at 2.5”. As it stands right now it’s about 3/4-1” of rake. Also added AMP power steps. Hope this helps some folks!
Which way are you rear shock resoviors facing? To the rear of the truck on both sides?
Ctimrun
Nov 15, 2021
69
56
PNW
2022 F150
Ford Performance bilstein leveling kit
Running with 270/70/18, wrangler ultra terrains. I went up one tire size which equates to 33s.
Looks great! Is your truck a max tow? Are the fronts set to 2” or 2.5”?
A_carrillo08
Adolf
Jan 27, 2023
Tx
I left them at 2". It seems like it may still have a hair of a rake, which I don't mind. But the look and the feel are 10x better. When I looked at the struts, it didn't look like they could be adjusted. I could be wrong though. They were the bilsteins. Not sure about max tow. It's an fx4, I don't have the trailer brake.
Jjdh
Jerimey
Nov 20, 2022
53
2022 F150 Platinum
Hvac
Newport
Mar 11, 2023
sacramento ca
Ford F150
Looks great! What height setting and tire size did you go with?
Love mine. Gives the truck a better stance IMO and ride quality. $2100 installed.
Do you
Thanks! 2.5 setting and General Grabber ATX 275/65/20 tires. No rubbing.
Great looking ride. Do you feel the ride quality on road is improved especially over rough roads? Now that it has settled how much rake do you have?
BWizard
Feb 24, 2023
Pittsburgh
2023 F150XLT BAP
Do you
Thanks! Just over a thousand miles mostly on road although some dirt back roads. Less body roll and does better with the bumps of a rough road. Have about 1 inch maybe a little more rake. With the Powerboost being heavier up front knew I would not get the full advertised lift amount.
Psw757
Mar 21, 2023
PA
F150 Platinum 2023
Any issues reported with the Ford Performance kit on the power boost model?
ng23
Jan 30, 2023
22152
2022 Lariat
Finally got my kit installed after they were back ordered! Love the look and the ride. I left mine on the standard 2” setting. The shop that installed mine put driver side reservoir facing forward vs towards rear as mentioned in the instructions. I don’t know if it makes a difference or not but they are going to flip shock over when I go back for torque check in 500 miles. The kit and the 275/65’s definitely improve the stance!
What lug nuts are you using here and how're they holding up? Got a set of rough country ones but those ones are already starting to rust after 2 months or so.
