JExpedition07
- James
- Feb 14, 2023
- 45
- 1,512
- 2,377
- Buffalo NY
- 2023 F-150 STX 5.0L V8
Just a quick little overview of what “Super 8.8” denotes
So in 2015 with the releases of the S550 Mustang and 13th gen F-150 Ford decided to revisit and redesign the 8.8” Sterling axle that had been in production throughout the nineties. If you are not aware, the Sterling 8.8 is the “LS engine” of the axle world, it is commonly retrofitted in Jeeps etc for off-road builds. The original 8.8 was a 28, and then 31 spline setup. Adding splines necessitates a larger diameter in the axle, so the 31 spline 8.8 is the most sought after version. Enter the “super 8.8” in 2015, Ford went to a 34 spline axle, increasing the axle diameter yet again to contend with the higher torque demands of modern powertrains. Attached (Left) is the old 31 spline 8.8 and (Right) is the new 34 spline Super 8.8 pinion
So what are the key upgrades?
- Front/outer & rear/inner pinion bearings in the Super 8.8 were carried over from the previous 9.75” Ford rear-end
- Crush sleeve, pinion seal, and pinion nut all came from the earlier 9.75” model
- 34 spline axles and differentials
