WHY DO MORE AND MORE AUTO DRIVERS TEND TO UPGRADE LED BULBS?
Status
Not open for further replies.
AUXITO Jackson
Feb 27, 2023
63
Upland, CA 91786
Website
www.auxito.com
2021 F-150
Senior Manager Of The Official AUXITO Brand Website
LED bulbs have become increasingly popular for use in cars due to the numerous benefits they offer over traditional incandescent bulbs. Some of the benefits of using LED bulbs in cars include:
💡Energy efficiency: LED bulbs use significantly less energy than traditional incandescent bulbs, which can help reduce the load on the car's battery and alternator. This can also translate into better fuel efficiency and lower emissions.
💡 Longevity: LED bulbs have a much longer lifespan than traditional incandescent bulbs, lasting up to 25 times longer. This can save car owners money on replacement bulbs over time.
💡Brightness: LED bulbs are brighter and provide more visibility on the road, which can enhance safety while driving.
💡Faster response time: LED bulbs illuminate almost instantly, which can provide a faster response time than traditional incandescent bulbs. This can be particularly important for brake lights and turn signals.
💡Durability: LED bulbs are more durable and resistant to shocks and vibrations than traditional incandescent bulbs, making them less likely to break or fail due to rough road conditions.
Overall, switching to LED bulbs in cars can provide a more energy-efficient, cost-effective, and safe lighting solution for drivers.
Halogen
Ford F-150 WHY DO MORE AND MORE AUTO DRIVERS TEND TO UPGRADE LED BULBS? 1678184402414
AUXITO LED
Ford F-150 WHY DO MORE AND MORE AUTO DRIVERS TEND TO UPGRADE LED BULBS? 1678184628395
If you have any unique ideas about LED bulbs you can leave your comments thanks.
My 2ND Ford
Jun 28, 2021
441
382
Ny
Halogen
AUXITO LED
As we get older, LED headlights allow people to see better at night , especially while driving in the rain . Taillight brightness in bad weather is also a plus.
sbi
Sep 4, 2020
82
1,245
841
Upstate SC
.....LED headlights allow people to see better at night
while dangerously blinding drivers in the opposite direction.
And before everyone jumps:
1. I am only referring to 'retrofits' that are not done right while drivers don't give a blank. Sadly there are many out there. Lights shine up, down and sideways. Not sure why in the United States nobody thinks that headlight must be tested for allignment, as it is in Europe and Israel for example (don't know about Canada).
2. I'll admit - I commited this sin myself in our Honda Accord. "If you can't fight them, join them". It became impossible to drive at night with the crazy bulbs and lights that peple put on their vehicles, not to mention fog lights when not needed and idiots who don't know - or don't care - their high beams are on.
My 2ND Ford
Jun 28, 2021
441
382
Ny
Yes, people that install light bars on their front bumper and then drive around with them on all the time. Headlight alignment check used to be part of yearly vehicle inspection in Ny, but was dropped long ago with the adoption of lights behind an additional cover.
RickBullotta
Rick
May 23, 2022
861
991
Pennsylvania
2021 F-150 Lariat Powerboost
LED bulbs can also confuse some bulb outage circuitry and trailer connection circuitry due to their low current draw...
AUXITO Jackson
AUXITO Jackson
Feb 27, 2023
63
Upland, CA 91786
Website
www.auxito.com
2021 F-150
Yes, your point sounds reasonable.
'It's true that some LED bulbs are too bright to cause blindness, but the advantage of AUXITOLED bulbs is that we have greatly improved the disadvantages of blindness.
They were fitted with 1:1 beam pattern technology and ultra-thin 0.039in the baseboard, AUXITO LED bulbs concentrate beams that shine further down the road and will not blind oncoming vehicles with a clear cutoff line.
Ford F-150 WHY DO MORE AND MORE AUTO DRIVERS TEND TO UPGRADE LED BULBS? IVE_LED_BULBS_3e99e7d5-cdc1-4224-9862-8cba37b52c61
Proper Bulb installation effectively reduces car light scattering problems.
In addition to using the latest technology to improve the performance of LED bulbs, it's also essential to ensure that they are installed correctly. Proper bulb installation can effectively reduce car light scattering problems and ensure that the light beam is focused in the right direction. By adjusting the bulb's position and ensuring that it is parallel to the arc in the reflector lens, drivers can avoid scattering and achieve a clear cutoff line. Combining the latest LED technology with correct installation techniques can help drivers achieve optimal visibility and reduce the risk of accidents on the road.
If the improper position bulb, then the light scattering does not focus which is not in the middle of the housing position, you will need to readjust the bulb position so that it is a 3-9 o'clock position which must be parallel to the arc in the reflector lens.
Ford F-150 WHY DO MORE AND MORE AUTO DRIVERS TEND TO UPGRADE LED BULBS? E_LED_BULBS-4_febf15e4-fb96-4c43-8c19-ef644ea058ef
If the light beam is scattered - remove the bulb;
1) Loosen the set screw at the base of the bulb;
2) Adjust the base and bulb to the proper setting;
3) Tighten the set screw after adjusting;
4) Install the bulb in the headlight, and confirm the position of the bulb is parallel correct.
5) Check the light beam.
HeadBanger
Ron
Oct 28, 2022
126
114
Finleyville, PA
2021 F150 XLT 5.0
There are a ton of stock vehicles which are blinding at night. I get high beamed all the time in my wife's Toyota Highlander and I've done nothing to it. Even had the dealer look into re-aiming the lights to ensure that there wasn't a problem.
I'd bet that even a 'leveled' truck would impact the oncoming traffic since the front is lifted - if the lights weren't re-aimed.
sbi
Sep 4, 2020
82
1,245
841
Upstate SC
I am 100% sure that lights on leveled truck are not aligned correctly and willing to bet that the majority of owners who level their trucks are unaware of that (or don't care 😉).
DT444T
Jake
Dec 29, 2021
397
349
21 AMB Powerboost Lariat
Meat servo
LOOK GUYS, I CAN TYPE IN ALL CAPITAL LETTERS! AND IF YOU USE THE CAPS LOCK KEY YOU DON'T EVEN NEED TO HOLD SHIFT. TECHNOLOGY SURE IS GREAT.
Graygoose2021
Nov 18, 2021
31
1,892
1,801
Central US!
Sales
haha mine too, wifes 2022 Highlander has awesome headlights, I get flashed at me, until I hit em with a quick "here's the real brights"
jeffrt
Sep 21, 2021
130
98
Belle River, Ontario
2021 F150 Lariat, 5.0L
No rules in Canada (or Ontario at least) that I know of. I wish there were. I live in a rural area, and get blinded constantly by people with LED swaps or misaligned headlights. Definitely passed a few new leveled F-150's that are blinding. Very frustrating and annoying.
  • Like
Reactions: sbi
AUXITO Jackson
AUXITO Jackson
Feb 27, 2023
63
Upland, CA 91786
Website
www.auxito.com
2021 F-150
AUXITO pushes the LED lights which in addition to preventing blindness design and makes auto users choose satisfactory LED bulbs at the same time to ensure that the bulb is energy-efficient, last longer, and emits less heat than traditional bulbs.
Maybe you have not used LED before, AUXITO hope can get a chance to let you know more about LED bulbs, if you are interested in LED bulbs to do a review, we are happy to send you free products for testing, maybe you can have a different thought about LED bulbs👍👍
unafFORDableXLT
Robb
Feb 19, 2022
43
Oregon
2022 F150 XLT
Even your own pictures prove the points of others….look how much higher the LED’s are shining light, and DIRECTLY INTO THE HOUSE BEHIND THE DRIVEWAY.
Your LED’s are shining DIRECTLY INTO THE EYES OF ONCOMING TRAFFIC.
AUXITO Jackson
AUXITO Jackson
Feb 27, 2023
63
Upland, CA 91786
Website
www.auxito.com
2021 F-150
Hi, that's just are higher lumen bulbs, we actually have a lot of LED products that are about the same brightness and color temperature as halogen, if you go to our website you'll see that we have lot of options of bulbs lumen , this will help you to choose the right brightness of LED bulbs. 👍
Status
