Whats the max boost your eco goes Shows 20 max but only goes to 10?
Westwood503
Clint
Apr 6, 2022
Portland OR
21 F150
Curious how much boost people are seeing. Have 21 platinum 3.5 eco and shows 20 max but when hammer it i gets about half way/ Is this typical? What you guys see on your boost gauge?
GIjoe
Joe
May 20, 2022
327
224
Ohio
2013 f250
When I first got my truck I was actually surprised how little the turbos actually work in normal driving but if I floor it, it does go to max boost. If I go aggressive but like 75% then boost only goes about half like your saying. I have the same engine btw.
12Lariat21
Jonathan
Mar 23, 2021
415
499
55374
2021 Lariat 502A
Engineering Manager
21 Lariat 3.5 eco boost. Seems about right, towing, accelerating hard with the 7000lb camper in tow it’ll go 90% to 100% of that 0-20 gauge.
drive mode will make a difference. In sport it should go a little higher.
KBKEITH
Dec 9, 2020
963
943
When I had a performance tune on my former ‘18 with the 3.5, I’d see boost in the 17-19 max psi range as measured from the psi gauge on the tune programmer. This was above stock levels of psi by probably a few points.
I could be wrong, but IIRC, stock boost levels were about 12-15 psi.
hotrodmex
Feb 4, 2022
973
855
Ca
22 Lariat 500.5a
Yeah, I've seen 15 psi quoted for the Gen 1.
I've seen text on the new turbos for the Gen 2 being capable of more PSI, but not that they are setup to do so.
@Westwood503 are you running 87 or 91+ gas?
powerboatr
Robert
May 9, 2022
134
3,096
3,485
North East Texas, Piney Woods
2022 F150 King Ranch 4x4
Retired Navy Senior Chief
i have seen half the scale and few times closer to 75%..so i assume thats 10 to 15 lbs
Westwood503
Clint
Apr 6, 2022
Portland OR
21 F150
I typically run 92 think wife put 87 in last fill up. I was in sport mode getting half boost will have to hook boat up and an see what she does with 92
antho
Anthony
Sep 20, 2021
778
733
Houston, Texas
2021 801A Raptor
mine peaks at 19. Only run 93 octane 3.5 H.O ecoboost.
Westwood503
Clint
Apr 6, 2022
Portland OR
21 F150
Been waiting for roush or ford perfomance to release the tune change to make reg 3.5 eco put out the raptor hp or 50 hp diff assuming its just tuning difference in raptor 3.5 and reg 3.5
TMCCOY
Aug 24, 2022
39
Utah
2022 F150 STX
Okay, dumb question: Where is the boost gauge? I haven't found one on my '22 STX, thinking it doesn't have one but maybe it does?
HSV_MIkeJ
Dec 25, 2021
234
174
Huntsville, AL
Website
www.music-by-mike.com
2021 Ford F-150 Lariat, SC Rapid Red
DJ
Raptor also has true dual exhaust and I think a bigger intercooler, but I assume most of the extra power is in a tune.
HSV_MIkeJ
Dec 25, 2021
234
174
Huntsville, AL
Website
DJ
Depends on your dash, but on mine you open the menu to configure gauges, and I swapped the transmission temp to turbo boost.
TMCCOY
Aug 24, 2022
39
Utah
2022 F150 STX
Thank you, I'll look at the menu options, but I'm not sure the STX has that.
hotrodmex
Feb 4, 2022
973
855
Ca
22 Lariat 500.5a
Different, larger turbos are the real difference.
I think the larger turbos was the gen 2, now it's the higher PSI in addition to what you mentioned.
Oxford_Powerboost
Austin
Jul 16, 2021
832
1,079
Northern Virginia
2023 F150 Lariat 5.0
Powerboost here. Depends on the weather. I saw it peg 20psi a time or two in the summer humid air. Now that it’s cooler, I may peak at 17 or 18 on the gauge and then settle in between 13-15 sustained. Running 93 octane
