MJ Heat
- Feb 5, 2022
- 10
- 302
- 302
- Obscurity, NC
- 2019 RCLB 5.0/2022 Powerboost/2023 Maverick Hybrid
- #16
I am exploring all options. I would like to do the 2nd remote that breaks the output off of the brake pedal. The brake must be depressed for the truck to start. I will go the OBD route if the brake output disconnect does not work out.The faraday blockers are one way but thats only if your key is involved. Like if you are inside your house sleeping etc. Your key gives off a signal, they use a amplifier and receiver to make the truck think the key is right there. They get in and take off.
The other way they do it is through the OBD port which doesn't care if your key is close by or not so the faraday stuff wont matter at that point. They plug up and essentially program a key on the spot and drive off. I don't know how they get in fast using this method but its been done. This is ideally a broken window.
Conclusion: Wouldn't do one without the other. Faraday is alot cheaper though thats for sure. Port blockers are like $190 USD but your covering yourself from both attacks.
We recently had a local festival where thieves walked around sucking up fob codes & transmitting them to cohorts in the parking lot. Cars were ransacked & robbed of personal items. I was not affected, but it prompted me to try to get ahead of the possibility of it happening to my vehicle.
