fxxkintallguy
- Kyle
- Mar 16, 2021
- 14
- 47
- 32
- Los Angeles, CA
- Website
- www.instagram.com
- 2021 F-150 XLT FX4 5.0L 302A 5.5 SB
- #31
Hey all, so I got my truck back from Ford after some routine maintenance and letting them know about this issue. I even showed them the video I posted earlier. They tested the truck and said that it was just a normal noise with the coyote engine apparently. The invoice I received after the service stated below:
I will note though that this description isn't very accurate. It's not a ticking or tapping, and it doesn't really happen at all RPMs. You can clearly hear it happening around 3200 rpm where the it almost sounds like a loose hanger or something, and its frequency kind of harmonizes with the engine as the RPMs get higher, then fades out past 3500-4000 rpm. This happens at all temperatures, and past 1700 rpm as stated in the SSM. So, we'll see I guess. I'll be writing this in the review survey they will be sending me as well.
"SSM 49761 - 2011-2021 Mustang/F-150 - 5.0L - Tick Tap And/Or Typewrite Noise at Idle
Some 2011-2019 Mustang and F-150 vehicles equipped with a 5.0L engine may exhibit a ticking noise at idle after an engine oil change. It is often referred to as typewriter noise because of its similarity to the sound of a mechanical typewriter. The noise in question may be heard on some engines when engine temperatures reach 150°F (65°C) or higher and engine speed is at idle up to approximately 1700 RPM's. It can typically be heard at the front wheel well, and is often isolated to the transmission bell housing or oil pan area. typewriter noise is not detrimental to engine function or durability and has no short or long term effects on the engine. This an operating characteristic of the 5.0L engine and no repairs should be attempted."
So...at least its in the records and if anything goes wrong later on, they'll see that I brought it in for that and they basically said its fine and to just ignore it haha.I will note though that this description isn't very accurate. It's not a ticking or tapping, and it doesn't really happen at all RPMs. You can clearly hear it happening around 3200 rpm where the it almost sounds like a loose hanger or something, and its frequency kind of harmonizes with the engine as the RPMs get higher, then fades out past 3500-4000 rpm. This happens at all temperatures, and past 1700 rpm as stated in the SSM. So, we'll see I guess. I'll be writing this in the review survey they will be sending me as well.
