Kayelmi
Not true. Ecoboost engines do not run really rich on cold starts. Also, during the break-in period you will get more fuel dilution because the rings aren’t fully seated. If this concerns you, two pieces of advice from someone that tests these engines for a living. Wait for your rpms to go down before putting into drive, avoids extra fuel during the cold start. Reduce constant short trips, the engine is designed to use this fuel once the engine is oil is up to temp and the fuel evaporates out and back to the intake. Also, for those doing fuel samples, take note of what your “engine on” times are or take a sample after a long trip, when the fuel has had a chance to get out of the oil. Otherwise, fuel% in the oil is mostly meaningless.
