spiritrider1
Thanks for that. I've got the 4x4 but did not get the FX4 package. I used to know how to access it on my 2018 STX 2x4 with key start. I would adjust the AFE Bias somewhere in the 935-936 range. It was probably off due to the 20" factory wheels. My new Powerboost has the same 20" diameter and with the same variance as I had with the 2018 of 1.2mpg I'm going to start with the same value and see where I end up!Engineering Test Mode 2021 F150
To access the trip computer fix on the 2021, kill the truck in Normal mode, open the door and then close the door to make the dash turn off. Wait a couple seconds for the screens to go black.
Hold the OK button (right steering wheel) for at least 5 seconds and continue holding until you see the message after the next step.
Apply brake and hold, start truck ignition (NOT ACC Only), and continue holding the OK button until you see Engineering Test Mode.
Cycle up or down 1 and it’s basically the only thing you can edit on the menu.
Question:
Are you 4x4 or 2x4?
