Highway MPG getting progressively worse
redline
Kyle
Oct 11, 2022
463
510
Calgary
2022 f150, BMW X5, BMW M3,
Sales
I am getting better mileage as the truck gets more mileage on it … run 18“ after market winters and i get 2 miles better then the factory 20”
I think I am going move to 18” summers as well.
I find wind really negatively effects mileage in this truck …
Dizz
Dana
Jun 22, 2023
128
76
WV
22 F150 STX 2.7 EB Crew cab
Above 55mph sucks gas
Above 70 double sucks
Any change from stock tires bad for mpg
As to tire pressure I only watch even tread wear and adjust weather it’s 25 psi or 45
Tires tuners and lifts all destroy mpg
Winter fuel blends hurt as well
Head winds and tail winds can cause 25% loss or gains
EcoB259
GB
Mar 3, 2023
160
127
22 XLT S Crew
If you do not recalibrate your speedometer when you change tire size it will give you false readings.
Going to a smaller tire will cause your speedometer to read a faster speed than you are actually going.
You may be getting better mpg because your driving slower.
TheGoatman
May 30, 2021
786
510
Powerboost
22 powerboost
Yup unfortunately badass tires hurt mpg. Goodyear territory AT. These look more aggressive than they are. They work like an oem tire.
good mpg, quiet, and soft on the potholes.
Def need to be cruise control, set to eco, at around 70mph to get north of 20mpg…the whole trip. No flooring it out of toll booths or passing. One or two of those and it’s game over too
redline
Kyle
Oct 11, 2022
463
510
Calgary
Sales
I am running all stock sizes, i am sure they will very slightly but not enough to matter
2BigDogs
Jim
Nov 15, 2023
85
86
NH
2024 GMC Denali Ultimate, 2017 MKZ
I'm seeing the same thing, however my 2023 Limited PB, 6600 miles, is bone stock. My previous truck, 2018 FX4 3.5EB with 20 in wheels, would consistently average 21.8 mpg year round on the highway running 75 - 80 mph. The new truck averages 18.5 at the same speeds. Around town is similar, 3 mpg less. Supposed to be better mpg with the hybrid... NOT!
elaudermilk
Nov 24, 2022
27
2022 F150 PowerBoost Hybrid Lariat
Agree here. Drove to central Missouri from Dallas last summer - tested theory out… staying under 73 mph has a dramatic effect on mileage. I’m leveled with Toyo at3s.
mtmiller302
Jan 10, 2021
SE PA
2021 F-150 XLT Powerboost
Third winter on my '21 PB. Winter MPG is definitely lower than summer. I wouldn't even think about MPG until next summer.
spiritrider1
Juan
Jan 13, 2021
318
253
Denton TX
21 F150 PB XLT Sport 4x4, 20 Mustang GT Conv.
Aircraft Tech & Maintenance planner
Keep in mind, everyone's experience will be different. The PB is not a Prius. It's main objective is to provide a system of supplying a power source for Pro Power. The side benefit is supplemental energy to augment the engine which helps reduce fuel consumption.
Every truck is specc'd differently. Different weights, tires, axle ratios, capacities, weather conditions, altitudes, hills vs. flat land, etc.
The mileage computer needs to be calibrated. There's a way to do that in the dash engineering mode. The factory mpg setting is the same on all trucks, set at an AFE Bias of 1000. Yet there are trucks delivered with 17" - 22" tires of different widths. Thats' a huge variable.
Either way, if you don't correct the AFE, then at least do manual calculations at every fill-up.
Winter fuel blends and octane will affect mpg. High altitude and using 85 pump gas will give you a much different result to using 93 at sea level.
Spirited driving is rewarded with invigorating performance - and an mpg hit. Turbo's can be efficient OR powerful. Finding that middle ground is not easy but most of us PB owners have found 70mph on level ground returns respectable mpg.
2 1/2 years of consistent 25 mile travel to work on 40/60 city/hwy in a variety of weather conditions and seasons provide a very good baseline. I'm averaging 23.2 over 42K miles. Each oil change I reset the #2 trip computer and let the mpg's carry forward while I reset the #1 trip computer at each fill-up. I also use the Fuelly app to keep track of consumption and maintenance.
A couple intervals were in the low 22's due to cross country driving with a full truck and trailering through Texas hill country.
I, for one, am happy to have a 430 hp, 570 tg 1/2 ton 4x4 truck that gets within a couple mpg's to what my brother does in a 4 cylinder Subary Cross Trek. AND with an on board generator.
EcoB259
GB
Mar 3, 2023
160
127
22 XLT S Crew
I thought you were switching from 20s to 18s if so, recalibration would be needed to be accurate.
TheGoatman
May 30, 2021
786
510
Powerboost
22 powerboost
I attached a pic of the tire. They are less expensive so I am ok with changing them more frequently if they don’t last as long as a ridge grappler.
I also noticed this tire in this size was chosen for the 25+ new Tahoe/suburban z71.
Ford F-150 Highway MPG getting progressively worse IMG_1271
During my trip, I ran through a bad downpour overnight for 4 hours. They are new but they worked great.
imho this is the most aggressive looking tire without giving up ANY comfort and on road quality.
I don’t have experience off road but do look more capable than the oe hankook and pirelli
westbayou
Gil
May 19, 2023
Bradenton, FL
2023 F150 Platinum
Guess I wasn't clear in my original post. The gas mileage has been dropping although NOTHING has changed. Even with the level and tires which are .2" taller than stock (also a 33"), I was getting over 20mpg on the highway until recently. At this point my only guess is winter blend gas?
RossRR
Ross
Dec 4, 2021
430
333
Minnesota
400 mile round trip yesterday; half at 75 mph, half at 60 mph with a 12 mph crosswind and I got 18.0 mpg; totally stock and on cruise control 90% of the time. That same trip gets 20 mpg in summer months. Of course summer is 80 F degrees and yesterday was 22 F degrees so a little different than Florida.
RickBullotta
Rick
May 23, 2022
34
1,020
1,247
Pennsylvania
2021 F-150 Lariat Powerboost
I'm curious if anyone is experiencing steadily decreasing highway MPG's as they put more mileage on their trucks. Just got back from a 550 mile round trip on mostly highway, and averaged a dismal 16.8mpg at around 75mph. I've got a Platinum FX4, leveled with 305/55/20 tires so almost stock size diameter. Just flipped 14K miles. City driving I'm still able to get over 20 on average, but I hit the highway and it drops like a ROCK. Overall I drive like a grandma but cruise between 75-78. When I had 5K miles on it 20-21mpg average for highway driving was the norm. I'm at a loss as nothing has changed in that time.
Did you put A/T tires on? And a 2" level definitely affects aerodynamics.
spiritrider1
Juan
Jan 13, 2021
318
253
Denton TX
Cruise will often give you worse MPG unless you are on very flat roads! Any hill will request the engine spool up to maintain speed. I don't use cruise in hilly areas because of this. I use physics and nature to help instead. Going downhill, I'll let the truck build up and carry more speed. As I'm going up the opposing hill I'll let speed bleed off then gradually apply throttle to keep it within a safe and appropriate speed for that part of road (i.e. not too slow!).
Having driven a lot of Texas Hill Country roads, you get pretty used to this technique. Trust me, It saves a lot of gas when doing 200+ miles of driving from San Antonio to N. Texas up FM-281. ;)
