Heated Steering Wheel Retrofit - updated with information
hotrodmex
Feb 4, 2022
973
855
Ca
22 Lariat 500.5a
Nice! Looks like they are using up old stock; I'll grab one before they move on to the 19980s.
I think the case here really is that one part number that everyone sees and eBayer use is the one on a large label, which isn't necessarily the number for the whole assembly. Each piece would have its own part number, and some are more prominently displayed that others.
I believe the 18C612 number is for the core electronic section, and the 19980 number is for the whole assembly.
I mean, if you search one you get eBay listings and no oem suppliers; search the other and you get all Ford parts warehouses.
Plus on the back plastic you can see both 19980 and 18C612 molded right next to each other, so it's not like the numbers are separate from one another.
I think they have to keep making this part because to switch to the other style you would need to make configuration changes to the APIM for the temp readouts on 21s, which would make this a dealer-only service, if they are even able to make configuration changes and not just load As-Builts? Dealers don't use FORscan, and they are not in the business of making modifications, just repairing.
Moe7
Feb 2, 2022
123
75
OH
2022 Tremor
That's good to know; I can't imagine they'll discontinue the part either, for the reasons you mentioned.
I thought I was slick and ordered a "-BE" version off LKQ that was sourced from and showed pictures of a high trim Lariat (would be a -DE, that I need); figured it'd be nice to have the initial configuration done and avoid the DTC.
Come to find out, they actually did send me a -BE.. At least there was a local storefront to avoid return shipping.
poomobile
Apr 4, 2022
BC
2021 f150
I installed my steering wheel and Sccm and new hvac controls today. Everything works great except I have no heated seats anymore for some reason. The indicator lights work on the hvac control but no heat. Can anyone shed any light on this for me? I ran the power wire to the location in picture below. Could I have knocked a heated seat wire loose? Is it in that same connector or is likely a forscan hvac programming issue? I’m stumped.
So I removed the hvac controls that I put in and put my old one back and the seats started to work again. I just went with the soft button on th screen. I’m not sure if the hvac control I bought was defective or not. I set it up properly in Forscsn and everything worked but the heated seats. Oh well.
B-real
Nov 14, 2022
333
256
Utah
2023 F150 Tremor 3.5
What is the programming to have the soft button on the screen, and can you do both (HVAC with hard button and soft button on screen)?
jpsmitty16
Josh
Apr 25, 2022
162
54
Buffalo, NY
My guess is you got a faulty hvac control. Exactly why it is an aftermarket part
poomobile
Apr 4, 2022
BC
2021 f150
You can do both. The programming for forscan is a few pages back
Iceman2022
Jake
Nov 7, 2022
60
2022 F150
Controls Engineer
When I got my clockspring I thought something was wrong with the hardware because the left steering wheel controls didn't work anymore. It turned out all I had to do was flash the module with my original as built data and everything worked as it should.
Iceman2022
Jake
Nov 7, 2022
60
2022 F150
Controls Engineer
Forgive me this is my first post in the forum and I have no idea how it works chronologically. I will be referencing conversations 10 pages back, lol. I have successfully installed a heated steering wheel in my XLT 302A this week. I read through this post like 100 times before I did it. There is more than enough info here to make it happen, but I did buy the kit from Boosted Grey Goose. The instructions they provide are awesome, but I was too impatient to wait for them to arrive before I tore my truck apart. The video @superfordman made was awesome. I bought the HVAC module from BGG but I’m not going to install it until I’m ready to do cooled seats. I originally switched the vehicle in the APIM to a super duty like @Jesse-Infotainment figured out but today found out that you can just enable the unreal theme and climate controls bar at the bottom, which I like better because it’s always right there and you don’t have to search for the card. And of course, thanks to @Livinitup for his amazing spreadsheet and the post about the climate bar in the unreal theme that I overlooked the first 100 times I read it.
Bullett
Matt
Mar 10, 2021
161
136
Saratoga NY
2021 F150 STX, 2016 Accord Touring
Accountant
Does anyone know if you can program the APIM to have the heated wheel button come up on the 8” screen in an stx?
dhageremtp
D
Feb 14, 2022
202
165
North Dakota
2022 F150 Lariat
Healthcare
Did you load your as built to the hvac module?
dolsen
Aug 19, 2022
2,081
1,900
KY
2022 Rapid Red 701A
yes I did. I spent hours trying to get it to work. It was a nightmare
Well if you wanted to try another module, in case the one was bad, at least you know you can get it for 1/3 to 1/4 the price they were selling at over the summer lol
superfordman
Troy
Jun 29, 2021
807
772
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
You should be able to if I'm correct. The 8" screen has the dedicated climate page that can be enabled like on the older trucks and then you can trigger it from there.
Jesse-Infotainment
Jesse
May 27, 2021
3,738
5,918
You can.. But it sucks. When its enabled the phone overlaps it and I dont even know you can access it. Also it is only available on the home screen. So I cant say for sure how well it works but it is possible
Bullett
Matt
Mar 10, 2021
161
136
Saratoga NY
Accountant
Thanks for the replies guys!
