Yeah who knows. There could be inconsistencies with the molding process too, maybe your tank is actually closer to 32 gallons.@12Lariat21 I drove roughly 30 miles after the 50 mile DTE warning leaving the range at 20 (I mentioned this to note the tank was quite close to E)
I was on level ground and did not “top off” I let the pump shut off automatically.
Also the ambient temperature was around 90* F I’ll bet the tanks are closer to 65-70 F underground. It seems intuitive that a gas tank designed to be pressurized does not change volume a great amount for an ambient temperature change
Not odd, lots of posts about tank capacity and how much you can put it when the gauge reads empty. I ran my 26 gal tank down to about 40 DTE and the most I squeezed it was about 22 gals. My brother in law has had 36 gal tanks for as long as I can remember and he says the same thing. Best he has ever put in was about 32 gal. However, having been in automotive for a long time and seeing what repeated low fuel quantity can do to a pump, I rarely run mine down past 1/4 tank.adding to the oddity, I've got the 36gal extend range tank on an ecoboost engine and I have yet to be able to fill more than 32 gals at the various pumps. I've consistently drive down to 0 DTE or even sometimes past 0 DTE by 3-4 miles, coasting most of the way. LOL.
There are some engineering drawings that on here that show the different tank designs in each of the eco/powerboosts and it does seem like a lower "reservoir area" that the fuel line feeds from. This might help assist in an inclined parked truck to always have gas to start and run.
