SpaceWhiteF150
- Sep 18, 2021
- 59
- 1,866
- 972
- Montgomery, Texas
- 2021 F150
Dang, looks amazing! What color did you paint the top trim piece? How much did it run you?Finished my Tremor skid plate install back in Sept as part of my front and rear Tremor clone conversion on my '21 Rapid Red F-150 crew 5.0 XLT 302A SPORT/FX4.
Up front...
Installed the Ford Performance Skid plate kit from local dealer (2 week delivery plus 20% discount) and Stage 3 Motorsport 2.3" Level Kit
Out back...
- Used Noah's (Stage3) method for installing the leveling kit.... Much faster and simpler.
- Followed the Ford's instructions to the "T" as I had to remove the bumper to repaint the front bumper from rock chips and prior owner's driving techniques.
- Painted black trim piece from skid kit to match with custom PPG color (Iconic not any closer than rattle can from Walmart)
- Painted the FX4 mid skid plate to match at the same time
- Had the front end aligned... camber and caster were fine just a little toe adj and steering wheel centering needed because of the lift.
- Front to rear rake is now 5/8" to 3/4" depending on fuel load (36 gal tank)
- Adjusted and aligned the fog lite to get them outta dirt from factory (now set one turn from top and even L to R).
- Lost the front license plate (sir.... umm.... it fell off, parts on back order)
Installed the factory dual exhaust setup from the Tremor/BAP package, lost the "wing dings" from the front of the rear wheels and painted the rear end (housing, center section and shocks). All ford factory parts from the Ford Parts catalog or Ford Performance.
Results...
- Ordered factory exhaust by the piece (bumper ends, muffler, L and R tailpipes, misc brackets and bolts). Got the parts numbers laying my back under Tremor and 5.0 BAP with camera and tape measure in the dealer's lot. It appears Ford Performance may have released new kits for rear bumper exit.
- Powder coated the exhaust tips. The factory coating wipes off. Same as the Raptor tips do.
- Re-positioned the wiring and hoses from the frame to the rear axle. Carefully bent and formed the hard lines and relocated the bracket forward of the axle. On the factory installed dual exhaust these items come down the spine of the truck. Too much work to replicate. As a result, I won't need the recall for the rear E-brake lockup due to wire chaffing.
- Added heat shielding to the new tail pipes fabricated from the shields on the factory single exhaust
- Assembled the rear bumper with exhaust cutouts and new location for the rear sensors. Had the bumper painted along with the front bumper.
- Left the spare tire in the shop... her butt looks better w/o it hanging down.
- The "wing dings" were replaced with '21+ F-150 Rocker Panel Aero Delete kit M-9929-F15.
Some pic's of the results...
- When I first fired it up it thru a few code and warning lights as it missed the rear sensors and camera when I drove in and out of the shop with these parts disconnected. But after few minutes and a power cycle everything came back just fine. All the camera modes and BLIS are happy and working as they were prior to the changes.
- Looks like it should have from the factory.
- Sounds amazing not loud at all. Just a nice rumble at idle and a growl when you work it... AND NO DRONE when it decides it needs to run with 4 cylinders.
- As for mileage... I got 16 MPG when I drove it home from dealer for 200 miles in a 30 MPH head wind. The next week I got almost 24 MPH on the highway for 100 miles. Then I just drove it like it was meant to be driven and I get 18 MPH around town and 22 plus on the highway at posted plus 10 MPH. After the changes, hard to say.... any hills, headwind or stop n' go and the mileage drops. Still logging 22 plus on the highway at posted plus 10MPH. Never have reproduced the one time almost 24 MPG. I believe the skid provides better aero than just removing the silly factory spoiler which exposes the front suspension to wind. The biggest problem is my foot as I can not get enough of the V8 sound and RPM's this motor turns. I have seen less than than 1 MPG pulling my RV at 6200 RPM in the acceleration lane... But damn that's fun.
