speedracercjr
Just checked that, does not appear that it's trying to load the 13" format. Also I didn't make any forscan edits to the APIM. Actually the only edit I've ever made through Forscan was the double honk which lives in the BCM.Just out of curiosity, if you go into Sync 4 test mode, (hold seek forward on steering wheel and dash at same time for several seconds while the radio is playing), get into APIM diagnostics and select resolution settings, is your 12" Sync 4 system trying to display the 13" dashcard format? That's sort of what it looks like.
Once you get into the test mode in Sync 4, locate the exit gracefully button in the APIM diagnostics at the bottom of the list and let it reboot itself.
Also, did you make any previous changes to the APIM as built before this update?
It loaded an older version of the APIM over the newer one which hosed it all up. I even got an app notification in the Ford app but the details just said "unable to provide information" or something to that effect.
