speedracercjr
Wonder why they are pushing two APIM updates without noticeable changes. Must be getting ready for some big change??
I am also stuck on 21281 rev244 ....... Are you suggesting the new APIM update will fix this issue of being stuck for me ?This does get all of us stuck on 21281 rev244 moving on.
Could you also check mine for the APIM update if it is waiting ? 1ftfw1ed3mfb23739Would anyone mind checking mine, I assume I have an APIM/TCU update waiting
1FTFW1E85MFA49677
You have a few updates ready.Could you also check mine for the APIM update if it is waiting ? 1ftfw1ed3mfb23739
thank youYou have a few updates ready.
Yep. It certainly does. I was stuck on 244 for quite some time. Did all the updates today. The GWM was the most problematic for me as it kept failing. Right before I was about to give up for the day, it finally completed the configuration successfully.I am also stuck on 21281 rev244 ....... Are you suggesting the new APIM update will fix this issue of being stuck for me ?
TCU first. It’ll automatically move to the APIM afterwards. You’ll get a GWM update after you complete the TCM and APIM. I’d do the IPC last as that will take the longest.thank you
what order do you suggest I run them in ? Will this fix my issue being stuck at 21281 revision 244
TCUthank you
@RellIk&5 did this give us xlts camera at speed?TCU first. It’ll automatically move to the APIM afterwards. You’ll get a GWM update after you complete the TCM and APIM. I’d do the IPC last as that will take the longest.
Yes there are new APIM/TCU/GWM updates out that a couple have applied to get over 2.3.0. I'm going to apply these today as well as I'm a 302A stuck at 21281 as well.Is there a solution to 2021 XLT 302a that is stuck on 2.3.0 update?
I got the 302A with the copilot 2.0 adaptive cruise.Yes there are new APIM/TCU/GWM updates out that a couple have applied to get over 2.3.0. I'm going to apply these today as well as I'm a 302A stuck at 21281 as well.
I forgot to check. My AC died in my truck so it's currently in with the service dept. Once I get it back, I'll check.@RellIk&5 did this give us xlts camera at speed?
