imnuts
- Mark
- Mar 1, 2021
- 23
- 1,501
- 1,568
- Dirty Jerz
- '21 502A Powerboost 4×4
- Facilities Engineer
Just because it's good at braking for a truck doesn't mean it's good at braking compared to other vehicles on the road. Braking distance also increases at the square of the increase in speed. If it takes ~140' to go from 60-0, it'll be ~560' to go from 120-0. If you're behind a car that has a 100' 60-0 braking distance, you need an extra 160' of space to stop before hitting them off your following them at 120 mph, assuming you have the same reaction time. The stability of a truck at speed is also much worse than a car, so if you'd have to suddenly swerve, odds are you're going to be rolling down the road and not in a good way, versus a car that is much less likely to have that happen.
So, just because you can didn't mean you should. As exciting as triple digits is, there's no where I needed to be that fast, and impacting the safety of everyone else on the road isn't worth it.
