turbospartan
What spacers did you go with?Thanks! Spacers are only in the back. Due to combo of sticking with 285 tires as well as no lift/level, my mpg has not been affected. Even if it has, it's not noticeable.
Thank you man. You saved a good amount of money and time. I was going to order 17" rims and just saw your comment.Bad news on the Raptor wheels. I just bought a set to put on my '21 XLT FX4 and the 17" wheels will not clear the rear brake calipers. They will go on, but will not spin once bolted down. I know there are factory options for 17" wheels so I was very surprised they did not fit, especially after watching this video. I do also have the max tow package, maybe that increases rear brake size? As you see in the video, no clearance issues in the front.
I believe you are correct about max tow package. I think I read somewhere that the larger brakes with it won't let you go below 18" wheels.Bad news on the Raptor wheels. I just bought a set to put on my '21 XLT FX4 and the 17" wheels will not clear the rear brake calipers. They will go on, but will not spin once bolted down. I know there are factory options for 17" wheels so I was very surprised they did not fit, especially after watching this video. I do also have the max tow package, maybe that increases rear brake size? As you see in the video, no clearance issues in the front.
I’d like to bump this.Can anyone confirm 295/70/18 will fit stock? Minor rubbing is ok.. just want to slap tires on and level later.
Just did 285/70/18 (34x11.5) Nitto Ridge Grapplers with the 2" readylift level. I like the width of the 285 over the 295 in my situation to ensure I have room if the suspension flexes while in full lock. I would think the same especially without the level. Its only .3" wider and taller with the 295's so if you are ok with a little rub, should be fine.Can anyone confirm 295/70/18 will fit stock? Minor rubbing is ok.. just want to slap tires on and level later.
Hm.. might see if discount tire will slap a 295/70 on and do a little rub check.Just did 285/70/18 (34x11.5) Nitto Ridge Grapplers with the 2" readylift level. I like the width of the 285 over the 295 in my situation to ensure I have room if the suspension flexes while in full lock. I would think the same especially without the level. Its only .3" wider and taller with the 295's so if you are ok with a little rub, should be fine.
Hi - do you have the max tow package? I’m hoping that 18” can fit with the larger brakes. ThanksJust did 285/70/18 (34x11.5) Nitto Ridge Grapplers with the 2" readylift level. I like the width of the 285 over the 295 in my situation to ensure I have room if the suspension flexes while in full lock. I would think the same especially without the level. Its only .3" wider and taller with the 295's so if you are ok with a little rub, should be fine.
Any rubbing when going over bump forward or turningJust put on 285x65x20 KO2s (34.6" tire) on a stock truck. No level. No rubbing whatsoever. I do have 1.5" spacers on order for the rear as the rears are a little tucked for my liking. Otherwise, I am quite happy with how it turned out.
Definetly do not raise the front when towing. Asking for trouble.I'm debating 285/65r20 vs 275/65/20, so these pics help for sure. Since I'll be towing a 6000lb TT, not sure I want to put on a 2" level. I did see motofab has a 1.5", but still think it'll be too much when towing.
Went with 285/60r20s back in December and will not be putting a level on it. It rides good as-is unloaded or when towing.Definetly do not raise the front when towing. Asking for trouble.
Thanks for this. I took your lead and put the same on my 2021 F1`50 Limited. Will probably get cursed for this, but I replaced the stock Limited 22s with Stock Platinum 20s, then put the same KO2 285x65x20s on. I like the look of of a bigger tire on this truck but wanted to keep it relatively stock looking. No lift or level. No rub.Just put on 285x65x20 KO2s (34.6" tire) on a stock truck. No level. No rubbing whatsoever. I do have 1.5" spacers on order for the rear as the rears are a little tucked for my liking. Otherwise, I am quite happy with how it turned out.
Looks good. Any rubbing?Went with 285/60r20s back in December and will not be putting a level on it. It rides good as-is unloaded or when towing.
