2021 F150 295/70/18 tires on +20 wheels?
McCarthy
Feb 26, 2021
2021 F150 Platinum
Guys need some help here, I have a 2021 Platinum with a 2" bilstein level. I put a set of 295/70/18 Falken AT3W's on a set of 18x9 fuel wheels with a +1 offset, they rub pretty bad on the fender liner and are extremely close to the front bumper. I have to decide today if I try a different offset wheel, or a smaller tire as the truck is sitting at the shop. They'll swap the wheels or tires, but not once it's been driven on. Need my truck tomorrow.
Can anyone with a 295/70/18 confirm if there's any rubbing with a + 18 or +20 offset?
Tizzzo
Ed
Feb 5, 2021
450
385
California
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
From what I've read and seen in videos the offset is what's killing you right now since you have a wider 295 tire. I would say go as least aggressive as possible to avoid any rub. +20 should work but cant confirm.
Tizzzo
Ed
Feb 5, 2021
450
385
California
Veteran
Check out this set up. These are 22 inch wheels 285/55/22 with a +12 offset and it fits, I punched it into the calculator and your set up is the same 34.3 height but you're slightly wider at 11.6 versus their 11.2, again this is at +12 offset so I'm assuming with a less aggressive offset (+18 or +20) you should be fine.
Tizzzo
Ed
Feb 5, 2021
450
385
California
Veteran
Here's another video, this one is much closer to your set up with this being a 17 inch wheel and +1 offset. Punched it into the calculator and if you get a 285/70/18 you'll have the exact same fit as the truck in this video. Looks like the offset isn't the issue and it can work but you would have to use a 285/70/18 instead of the 295. It will be close though, so either use a less aggressive offset or a tire that isn't so wide. Hope this helps!
g1teg
Sep 2, 2021
K0A2p0
2021 F-150
Small business owner
What did you go with? I already bought Fuel Blocks, 18x9 with a +20 offset ( got them for cheap) and Im trying to figure out what tire to go with. Was looking at the 295/70R18 but would like to confirm.
I have a 2" Level in front on a '21 XLT FX4
Ford F-150 2021 F150 295/70/18 tires on +20 wheels? 30728b73-e0a3-4638-b79b-f2997ef4c650
Dark_Horse
May 19, 2022
2Ligit
2021 F150 Lariat FX4
I have a 2021 F150 Lariat FX4 with a 2 in level (tuff country). Just bought 18x9 fuel tech wheels +20 with ridge grapplers 295/70 r18. No rubbing on the road. Looks like there is plenty room. I'll try off-roading and see how it goes.
Hanger51
May 6, 2022
2010 F150 raptor
Construction
Hows your wheel and tire set up holding up, Still no rubbing ?
