windowsmedia10
- Feb 14, 2022
- 5
- 60
- 56
- Toronto, CA
- 2023 F-150 Lariat 502A PowerBoost
Hey Everybody,
I took delivery of my 2023 502A Lariat Powerboost a few weeks ago. Here are my initial thoughts:
I'm coming from a nearly identical truck that I put about 50000 miles on. It was also a 502A but it had the 2.7 and was an FX4 truck.
- This thing hauls ass. I thought my 2.7 was quick (and it was) but this thing is a rocketship. There is zero shortage of power. Trying to hypermile it in the city is neat and I was surprised how far you can go in electric only mode while cruising on flat ground.
- The transitions between full electric mode and hybrid ICE mode are well done. Not perfect by any means and every now and then you get a minor note of harshness with a downshift or transition but they are generally pretty good.
- I immediately noticed that when the battery is working in conjunction with the ICE to move the vehicle, it helps to keep the turbos from spooling up like they usually would under similar load conditions.
- There is a bit of a disconnectedness to the powertrain that is difficult to describe. Not in an overly negative fashion, just quite different. When you're really on the throttle you do get a clear sense that the engine is doing its work while an invisible force (the electric motor) is pushing/aiding it. Almost like a really strong tailwind.
- The piped in faux engine noise is not the best. I've noticed that at times there is a disconnect from what you are hearing and what the truck is actually doing. There is also a bit of a low drone noise that I'm pretty sure is coming from the subwoofer under the rear seat when cruising around highway speeds. I'm going to try turning that stuff off using Forscan to see the difference.
- There is a small white cord that hangs down from the rear driver side wheel well that is the manual opener for the gas cap. Also helps if your door won't close. Also neat that at least portions of the system are pressurised. You can hear a little pump of some kind running when you close the fuel door.
- I ordered my truck with the optional Continuously Controlled Damping system. I can already tell you that this should be a must check option for anyone who wants the smoothest ride possible. My MY21 Lariat had the FX4 package and I thought that rode very well. But this CCD setup takes it to a different level. If you think of the bumps you encounter on a road being like a periodic function on a graph, the CCD system lowers the maximum amplitude of what you encounter. Bumps don't have the same sort of harshness to them. You feel them but they just aren't as bad anymore. It's unfortunate that the damping rates are only adjustable by using the drive mode selector. But it's neat to see the difference between Normal, Sport, and Eco especially. Again if you're on the fence, I highly recommend that you check this option box. It's worth it. I'm going to put together a separate post about the CCD system since there is so little out there.
- EcoIdle is neat. It raises the RPMs of the truck to about 1300 when you are idling to charge the battery more efficiently. I'm amazed at how long the truck can sit in park and idle without the ICE coming on, even with lots of accessories and the AC running.
- Speaking of the Air Conditioning system, it's incredible to have one that is run off the high voltage system and not the ICE. Idling is smoother and the system blows cold even if the ICE has been off for significant periods of time.
- This might sound silly, but I miss my FX4 fender badge. The 'Sport 4x4' emblem just doesn't have the same sort of presence and most people tend to read that to be the model/trim of the truck. My wife also commented that I'm one of the least sporty people that she knows…
- I've noticed some subtle differences/refinements going from an early build Job 1 MY21 truck to a Feb MY23 truck. Both my trucks have had the B&O Unleashed system but this new truck somehow sounds better with the same settings. Crispier, a refined surround mode, clearer bass. The way wind related noise is insulated by rubber trim near the bottom corners of the windscreen is much more robust. My rear centre window doesn't rattle when listening to music. (yes, there was a TSB for that). The 75th anniversary etching into the windscreen and on the Sync 4 screen is neat, the gear shifter doesn't have as much play in it, the steering feel is slightly sharper, the driveshaft seems to be better balanced, and I can't tell the difference between 4A and 2H mode nearly as much. The front park sensors are a neat addition, same with the wireless charger for your phone. I don't miss the digital temperature readouts on the dials as much as I thought I would and my MY23 truck came with a heated steering wheel so no retrofit was required. The seat foam seems a bit softer than before, specially the side cushion bolsters, and the middle headrest in the back is shaped differently.
- Sync 4 seems snappier. Different CPU maybe or some sort of other hardware differences we are not aware of? I had used FDRS to completely update my old truck so I'm comparing recent versions to each other… it just feels different and less buggy.
- The spray liner is far superior to the drop in liner I had before. If you're leasing the difference between the two is negligible given you can residualize out accessories. Would get the spray again in a heartbeat.
- I did not opt for the 7.2kW Pro Power system since I have a generator for our house. But it is still nice to have the 2.4kW system in the bed just in case.
- I replaced the license plate tail lights right away. The incandescent bulbs Ford provides by default really dont match the rest of the lighting on the truck and they run hot. I posted a video over here to describe how to do that.
