marekjk
- Marek
- Apr 1, 2023
- 3
- 81
- 43
- North Richland Hills, TX
- 23’ F150 Powerboost Lariat
The F150 Powerboost that I have had for the last two and a half months went nanners on me this morning. The truck has been solid up until this morning. It only has 2100 miles on it and I purchased it brand new.
As usual, I pile my litter of children into the truck, depress brake pedal and press the ignition button. Instead of the vehicle starting normally, it enters “Full Accessory Power”. I thought that maybe I did not depress the break pedal, so I shut everything off and repeat the sequence, only for the same thing to happen.
The car was stuck in “Full Accessory Power” mode for two hours no matter what I did.
As the truck would enter this “Full Accessory Power” mode, it would also tell me that I need to “Stop safely now”. Which didn’t make sense since I was not moving and the truck was off. I ended up turning off all sensors, driver assist, backup assist, etc, and repeating the ignition sequence... this did not work.
Car battery was fine. I also disconnected car battery from terminals for 10 minutes, this did not help.
Turned truck off, locked doors, and walked away for 10 min, did not help.
Tried remote start from FOB, did not work.
Tried to start from FordPass, did not work initially but this is how I got the truck started after two hours of tinkering. Before I did this I let it sit for 10-15 minutes as I was searching forums for a solution.
Has anyone encountered this before? Any input would be appreciated!!!!!
