VAS
I have a new 2021 Powerboost with 3K miles. Just completed my first RV tow, spread out over two days. Once each day I got a warning that the coolant was overheated. First day, ran for a hundred miles and stopped for a break/lunch. Turned on the AC. Ran for another hundred or so (almost 2 hours) and got the 1st warning. Pulled over right away and let it cool for 30 minutes. Did a visual on the coolant resevoir. Was not low. Completed day 1 without the AC on and no more warnings. Next morning, checked the coolant again, not low, so headed out. Pretty much the same scenario. Only this time, it took less than a hour of the AC being on when the warning came on. Sat for 30 minutes again. And again completed the rest of the trip without AC.
My questions are this:
1) How is the temperature gauge on my dashboard supposed to operate? Because, the whole time it was sitting right in the middle, at "50%". It never moved. When the warning message came on, the little temperature symbol turned red, that's it. Isn't the guage supposed to move as the temperature changes. Shouldn't I be able to tell its getting hot before the warning message appears? One of the pics on this thread shows the guage in about a "3/4" position when hot. I would have expected mine to work this way.
2) I've seen the pics others have posted where thier truck displays an actual temperature also. Mine did not do that either. Should it have??
3) Was my truck even overheated at all?? The guage didn't move. Could the warning message be in error??
Any other ideas?
8000 lb RV, highway driving at 60 MPH, mid 80s on day one, and cooler (about 80) on day two. My exact configuration is rated for 12,4000 lbs. Yes, I know there is a lot of "marketing" in that number. Hence, my RV at only 66% of that weight. I shouldn't be having this issue. I've read the the PB has the most robust coolant setup out there. Is that not true? The tow experience was fantastic... up until I got the first warning.
If I can't tow (well below the advertised weight limits) during summer months with the AC on, then it completely defeats the entire reason I upgraded to this truck!
Any other ideas?
