2021 F150 4WD BDS 6" Suspension Lift with Fox 2.0 Rear Shocks 1579FS
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
In stock and available to ship for anyone in the market, Shoot me a message for forum pricing.
Frank
Ford F-150 2021 F150 4WD BDS 6" Suspension Lift with Fox 2.0 Rear Shocks 1579FS 150%204WD%20BDS%206in%20Fox%2020%20Lift%20Kit%2000
2021 F150 BDS 6" Lift Kit Features:
  • Big, bad 6" F150 lift kit with quality components
  • Adds 6" of front ride height for great look and tire clearance
  • Comes with Fox 2.0 rear shocks for improved handling
  • Strong crossmembers, lifted knuckles, and differential drop
  • Includes 5" rear lift blocks with U-bolts and nuts
  • Backed by BDS's "No BS" Lifetime Warranty
  • Requires cutting, trimming, and drilling
  • Will not fit diesel, Tremor, or CCD-equipped models
Provides 6" of Lift for a Great Look and Big-Time Tire Clearance in a Quality Lift Kit
If want to give your 2021 F150 a big, bad look and get the clearance to easily fit a 35x12.50" tire, then a 6" lift kit is one of your best bets. The BDS 6" Lift Kit for 2021 F150s is one of the toughest built, high-quality suspension lift kits on the market for the 2021 F150s. Each BDS 6" lift kit was built from the ground up to handle practically any application you have in mind for your hyper-tough 2021 F150 build. This version of BDS's 2021 F150 lift kit even comes with full-length Fox 2.0 rear shocks that provide improved rear-end stability, excellent handling, and improved off-road performance over the stock shocks and most other white-body and black-body lift kit shocks. The BDS 6" lift kit comes with thick, gusseted crossmembers and high-quality hardware that makes the BDS kit able to handle the roughest terrain and the toughest jobs on the planet. The BDS lift kit provides 6" of front lift and just enough rear lift to provide a near-level stance while allowing your 2021 F150 to clear a 35x12.50" tire with the right wheel backspace.6" of Front Lift from Bolt-On Strut Spacers, Heavy-Duty Crossmembers, Lifted Steering Knuckles, and Hardware
The BDS 2021 F150 lift kit adds 6" of front ride height to your 2021 F150 and comes with everything you need to get your suspension geometry back into a proper range at your F150's new ride height. The BDS kit's actual lift is provided by a pair of strut spacers that install on top of your F150's factory coilover assemblies. To compensate for the increased lift, each BDS lift kit comes with a pair of dropped crossmembers that are made out fabricated and gusseted 1/4" thick steel that are strong enough to handle whatever you throw at them. The front and rear crossmembers are bridged by a 1/4" thick differential skid plate to protect your F150's differential. The differential is lowered by included drop brackets to maintain a good CV and front driveshaft geometry. The front of the kit is rounded out by a pair of CNC, ductile iron steering knuckles with extended spindles and higher tie rod and hub mounts to further correct your F150's UCA, tie rod, and CV angles. Each kit also comes with a set of sway bar drop brackets and other hardware to complete your 2021 F150 lift kit installation.Comes with 5" Rear Blocks, new U-Bolts, and Fox 2.0 Rear Shocks
For the rear of your F150, BDS includes new lift hardware and high-quality Fox shocks so that your 2021 F150 gets extra lift and a great ride. The actual lift is provided by a pair of 5" rear blocks that replace the stock blocks and install between your F150's rear axle and leaf springs using new U-bolts and nuts. Since the factory shocks can't handle the lift, BDS includes a pair of Fox 2.0 rear shocks that are long enough to handle the lift blocks. The Fox 2.0s feature a gas-charged monotube internal design inside a 2" diameter, aluminum shock body that provides a huge improvement in handling and rear-end stability than the factory rear shocks, as well as greatly improved off-road performance. Rounding out the rear-end components are a bump stop extension, brake line extension bracket, and rear driveshaft spacer. BDS backs their lift components with their legendary "No BS Hardcore Lifetime Warranty" where if you manage to break something, BDS will replace it.
Fitment: 2021 F150 4WD
Two-piece driveshaft note: F150s with a two-piece driveshaft will require BDS's carrier bearing shim kit here. Please ensure your F150's driveshaft type before ordering.
Will not fit diesel, Tremor, or models with CCD: this lift kit will not fit 2021 F150s with a 3.0L Powerstroke diesel, 2021 F150 Tremors, or 2021 F150s with OEM Continuous Controlled Damping (CCD) systems.
Requires cutting, trimming, and drilling: this lift kit requires trimming, cutting, and drilling of your F150's subframe for install. We strongly recommend a professional installation.
Backspacing requirements: this kit requires an 18" diameter wheel with a maximum of a 5.75" backspacing in order to clear a 12.50" wide tire. BDS recommends a maximum backspace of 5.50" backspace to avoid crash bar contact. Stock 17" or 18" wheels are not compatible with this lift kit. Stock 20" wheels can be reused, but they'll be limited to a 305 wide tire.
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
