F150 Roush Fox 2.0 Suspension System 422014
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
202
470
310
2021 F150 STX CrewCab 4x4
Since I have received this question a few times this week I wanted to make this post so those that those who are interested are informed and are aware that these are usually in stock @ Stage3.
-We do not have them listed on our website for fitment on the 21 (roush does and this is the same kit)
- Since Fox has said they don't recommend their kit for the 21 and are making a 21 specific kit, we chose not to list either for fitment.
- as you will see plenty of people are running these kits, so they will work with height adjustments.
31 kits in stock and shipping today,
Anyone who is interested message me for forum pricing.
Frank
2015-2020 4WD F150 Roush Fox 2.0 Suspension System 422014
Highlights:
  • Awesome suspension overhaul for your F150
  • Includes Fox 2.0 coilovers, 2.0 rear shocks, and Roost Shields
  • Adds up to 2" of front leveling
  • Rear shocks handle up to 1.5" of rear lift
  • Drop-in replacements for factory components
Complete Roush Fox 2.0 Suspension Package
When Roush went looking for a suspension system to put on their very own Roush-made F150s, they turned to the suspension wizards at Fox and their 2.0 Front Coilovers and 2.0 Rear Shocks to seal the deal. This Roush Fox 2.0 Suspension System comes with a pair of Fox 2.0 Front Coilovers, a pair of Fox 2.0 rear shocks, and a pair of Fox 2.0 Roost Shields for the rear shocks and gives your 2015-2020 F150 of choice a huge improvement in both on-road handling and off-road performance. The front coilovers even provide up to 2" of front leveling which allows you to clear larger wheel and tire combinations and score some extra ground clearance for your potential off-road adventures. Both the front coilovers and rear shocks drop right into place of your F150's factory coilover assemblies and rear shocks, making the Roush Fox 2.0 System a hassle-free way to give your F150 the suspension performance that it really deserves. Front Adjustable 2.0 Coilovers with up to 2" of Leveling
For the front of your F150, FOX gives you a set of their awesome 2.0 Adjustable Coilovers to replace the stock shocks and springs. The coilovers provide vastly improved rebound, compression, and articulation while still keeping your factory ride when you're on pavement. The coilovers feature adjustable ride height from 0" to 2", making them a great way to level out the front of your truck to get on bigger tires. They come pre-set at 2" of ride height to give you maximum leveling right out of the box. The coilovers have nitrogen-charged design with a 5/8" chrome plated and heat-treat shaft that's built for performance and reliability. These aluminum body 2.0 coilovers are wrapped in finely-tuned coilover springs that deliver a excellent performance. Fade-Resistant Aluminum Body Shocks
Update your truck's rear suspension with a pair of FOX 2.0 Aluminum-Body Shocks that drop right into place of your stock shocks and provide improved stability and heat dissipation. Like the coilovers up front, these shocks are made out of 6061-T6 aluminum and use an Internal Floating Piston (IFP) design to provide improved response while handling up to an extra 1.5" of rear lift. The shock has an internal reservoir design with specially formulated oil that resists heat buildup for reduced fade. The shocks are paired up with a set of Fox 2.0 Roost shields that add some protection and longevity to your Fox rear shocks.
Fitment: 2015-2020 F150 4WD.
Puckett88
Neal
Sep 28, 2021
72
F150 Tremor 402A Package - MX4 Cover & Bed Liner
All 3 fox kits in stock, read fitment notes above.
I bought a tremor last week. Curious to know what the ride height difference would be if i went with these coilovers vs a standard level kit with the stock suspension? I don't want the height of the truck to come down at all in the rear as i think it looks perfect the way it is at stock height.
Thanks!
Jeremy
Jeremy
May 13, 2021
Ohio
Will this kit work with 20x9+1 295/60r20?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
202
470
310
Thanks!
The rear will not be affected at all, as far as the difference in the front vs the stock with a spacer im not sure of that answer with the tremor unfortunately.
Yes it will, if interested feel free to shoot me a message.
Frank
Mike D
May 17, 2021
44
28
Maryland
2021 F-150 XLT sport 302A
Gov
Any idea when FOX will release the redesigned coil-overs for the 21?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
202
470
310
wolfnards
Nov 5, 2021
Boston
In stock and shipping and you can earn double rewards points through the end of the month.
Shoot me a message for best pricing
Hey @Stage3Motorsports Frank - I have a ‘22 F-150 Lariat Powerboost with Tow Package.
I’m interested in both the Ford Performance Fox 2.0 (M-18000-F15A) and the Roush Fox 2.0 (422014) kits.
0) I see Ford has an updated kit, M-18000-F15AA (ends in two ‘A’s). Do you stock those instead?
1) Can you PM me the forum discount pricing for both kits? Are they both in stock?
2) For my vehicle, does one kit have slightly higher lift than the other? e.g. 2” vs. 2.25”? Or are they both 2”?
3) I’ve seen a few forum posts where they claim 295/75/R18 with 18x9 offset +1 should fit with these kits and no trimming. Can you confirm this?
Thanks!
Wolf
