For those of you looking to do a little more than the normal level, but not wanting to quite go to a "full lift kit".
2021-2022 F150 4WD ReadyLift 3.5" SST Lift Kit with UCAs 69-21350
2021-2022 F150 ReadyLift SST Lift Kit Features:
While your 2021-2022 F150 is one heck of a capable truck right off the showroom floor, getting it ready it for big tires for some off-road or overland adventures means you're going to need a good amount of lift. The ReadyLift 3.5" SST Lift Kit for 2021-2022 F150s adds 3.5" of front lift to your aggressive 2021-2022 F150 and 1.25" of rear lift so that your truck gets a big, bad look and the ability to mount up 33" tires without a ton of hassles or big hit to your wallet. Each 2021-2022 F150 SST Lift Kit uses a combination of strut spacer and spring preload spacer to achieve front lift and a larger rear block and shock extension for the rear lift so that you get everything you need to add ride height to your truck and squeeze on larger wheel and tire combinations. The kit also includes a pair of ReadyLift tubular upper control arms that help adjust your front suspension geometry to better work with the 3.5" of ride height provided by the kit's actual lift components.
Billet Aluminum Spacers with Tubular Steel UCAs, Powder Coated Steel Rear Blocks, and Installation Hardware
ReadyLift builds each of their 2021-2022 F150 SST Lift Kits out of high-quality materials and carefully designed the kit for a perfect fit with low impact on your 2021-2022 F150's ride quality or handling. The SST Lift Kit's front leveling spacer and spring preload spacer are both made out of durable and corrosion-resistant billet aluminum that's precisely CNC machined for a perfect fit on your F150's factory strut assemblies. Each of the UCAs included in this kit are made out of strong tubular steel and come standard with an OE-style ball joint that provides excellent longevity. The UCAs were specifically designed to work with the lifted height provided by the spacers so that you avoid spring contact and other geometry-related issues. The rear blocks are made out of fabricated steel with a black powder coat finish and come with new U-bolts and U-bolt nuts that allow for their drop-in installation on your axle. The rear shock extensions are made out of billet aluminum and install in the upper shock mount to put the rear shocks in a proper range of travel at the new lift height. Each kit comes with installation instructions and comes backed by a limited lifetime warranty.
Fitment: 2021-2022 F150 4WD
For 4WD Only: this version of ReadyLift's SST kit only fits 4WD F150s. A version for RWD/2WD F150s is right here.
Not yet tested on PowerBoost: this kit has not yet been tested on PowerBoost models, and ReadyLift cannot guarantee fitment on 2021-2022 F150 PowerBoosts.
NOTE: Not for use on trucks that are factory pre-lifted/leveled or that have the "off-road package" like Tremor and FX4 Edition. Check factory height prior to ordering or installing. Trucks with more than 22" of wheel hub to fender lip height may require less lift.
- Provides a big increase in ride height for increased tire clearance
- Complete front and rear 2021-2022 F150 lift kit
- Adds 3.5" of front lift and 1.25" of rear lift
- Comes with strut spacers and spring preload spacer for front lift
- Includes tubular UCAs for helping to correct geometry
- Rear lift provided by larger rear blocks with U-bolts and nuts
- Backed by a limited lifetime warranty
- Not yet tested on PowerBoost
