VDM module SUSPENSION PROGRAMMING: making the ride FIRM in Normal mode.....
billkran
Jul 21, 2023
91344
2022 F150 LIMITED 3.5EB
RETIRED
OK, something changed in my software to allow me to access the Kg values.
Not sure what happened, but there it was in the VDM moduel:
2022 Limited 3.5
Curb weight = 715kg
Curb weight = 1598
It now allows me to double click on each value and change them.
I tried changing to 900 / 1984 : almost like 'sport' mode suspension, but just slightly softer
Then I tried changing to 990 / 2183: now it is halfway between the feel in 'sport' mode and the feel you get when you unplug the right rear shock sensor. It's very firm, but not too harsh !
Fantastic!
Combined with a rear sway (in transit) this car should actualy go around corners and over speed bumps like it was relatively normal !
Thank you Bruce for introducin me to the process !
DBL R
Jarred
Oct 11, 2021
411
592
Washington
2021 F150 powerboost
PA
2022 Limited 3.5
Curb weight = 715kg
Curb weight = 1598
Fantastic!
is that 990 just for the front? Or did you adjust the rear as well?
billkran
Jul 21, 2023
91344
RETIRED
It is a 'curb weight' adjustment.
It affects front and rear at the same time
You cannot adjust front and rear separately.
Essentially what you are doing is telling the computer that the curb weight of the truck has changed, and that it needs to compensate for that.
I also added a 1" lowering shackle and sway bar in the rear, and now I can drive with one hand on the freeway. Before it took two hands, constantly overcorrecting to stay in the lane.
It still rides HORRIBLE for a modern vehicle, but it's much better.
Ford should be very ashamed of themselves for deliverying such a terribly set up vehicle.
DBL R
Jarred
Oct 11, 2021
411
592
Washington
PA
so did you just change the “02EE” and leave the “020D” the same? Or did you change a different value?
billkran
Jul 21, 2023
91344
RETIRED
When you get to the proper module, there will be no tables, just a 'value' box that you can change.
nrs1417
Nick
Mar 15, 2024
Washington
2018 Expedtion
What year model is your truck and have you ever had anyone check your VIN for PCM updates?
A 2021-2022(Job1) truck will be helped noticeably by the improvements in drivability that the multiple PCM updates that Ford has released since the earlier builds. On the Powerboost the refinements are wonderful.
You might also try unplugging the rear driver's side CCD shock and see if you aren't just happier with the maximum damping setting full time?
I find it tempting to do if I wasn't going to go through the fuss of "tuning" the VDM and modifying the suspension physically. (RAS/Antisway bars/etc)
How would we go about looking for PCM updates?
9,235
16,907
If you are fortunate enough to have a truck that receives OTA updates successfully, you are getting the multiple PCM updates that have been released since 2021 Job1 trucks shipped.
If not, you would need to manually install using FDRS. (view the infamous FDRS thread for all you could ever want to know regarding)
Micasa1639
Michael
Jan 30, 2024
07755
2023 F150 Platnium, 2017 BMW 540I xDrive
Pilot
I just updated my vdm to red 990 and 2183 and it is a great change! Next step it a rear sway bar but these values will be great for now.
Thanks for all the hard work and trial and error!!!
9,235
16,907
Good job!
Just curious if your factory Asbuilt values for your truck was the same as the values I posted?
Surely a 157" KingRanch should have different values than a lighter or heavier F150?
