fgutz3rd
I s been posting alot guys because I am new to the whole lifted trucks and big tires. I was reading that when you go up in tire size you need to re do your gearing so the truck will run at it’s optimal with the new bigger tires. My 2021 F 150 Powerboost FX4 with a 3 inch lift. The stock tires were 275/65/R18 and the new tires I went with are the Nitto Recon Grapplers LT295 /70 R18 129R E1 BSW. We enjoy taking the RV out is why I went with E rated tires. I found this gear ratio calculator and this is what the results were. Is this really necessary, will my truck perform normal. I managed to get my speedometer within 1 mph under so I’m good with that. So If I do need to make the changes, can I change it using Forscan? Oh truck came with 3.73 gears. Any help would be appreciated.
