gtotco
I was playing a bit by focusing on the crawling aspect but either way based on the premise of the original post if the PB isn’t good for a 4x4 setup then likely wouldn’t be good as a “mall crawler” either.Not exactly, as I understand it, a "Mall Crawler" is a 4X4 that never goes off-road, even though it's equipped to do so. So, yes a Mall crawler would likely be lifted but the primary point is that it's not really used for it's intended purpose. Least that's how most of the folks over on the Gladiator forum used it
You're also correct that the sheer size of these things is a bigger obstacle off road than ground clearance in many cases, Espescially east of the Missisipi where most trails are tightly bordered by trees. If you're out in the open desert out west, not so much.
