Jerome10
2023 Powerboost I bought in May. Automatic climate control was working just fine in warmer weather.
Last couple mornings now we are below freezing where I live and I'm having a strange issue (maybe) with the automatic climate control getting me way too hot, particularly the footwell area.
Every other car I've been in with auto climate, I set around, say 68 and I just leave it for the winter. Warms up the car then gradually decreases temp and fan and its comfortable.
But the F150 I set the climate at say, 66 or 67. Truck starts warming up but after 5-10 minutes the cabin is getting HOT. As in I feel like I want to take my fleece jacket off. My feet in particular are getting roasted.
So I turn the temp down to something like 62. It seems to blow a little less hot but still seems rather hot air is coming out of the vents. I would say this becomes acceptable but 62 is pretty cold and only 2 degrees from just setting it on LO, which seems absurd when it is 25 degrees outside.
Then yesterday I was finally in the truck for a pretty long drive, leaving the heat at 62 (I also turned the 3-light auto fan button down to 1 light to prevent so much heat from getting pushed) and eventually I started getting cold. The air out of the vents was definitely cool... which is what I'd expect if I had a car set at 62 because 62 is indeed too cold a setting. So I had to then turn the temp up to 65 or 66 to get a proper feeling temp coming out of the vents.
I read a bit on the other forum out there and others have complained about this but didn't sound like any solution found there. Couldn't find a discussion here about this so wanted to ask.
I almost suspect this is not a problem with my truck but rather poor design possibly. Like the thermometer reading the cabin temp is in a bad location or something that remains cold for too long, so the truck keeps pumping too much heat even though the passenger area is at the correct temperature? Then eventually the cabin fully warms up, the thermometer finally warms up to 62, and it switches thinking you want it colder... and then you have to turn the temp up?
I've just never been in a car, including other Ford sedans over the years, where I feel like I get sweated out at 62 then it becomes too cold and I have to turn the temp up 4-5 degrees. Seems very all-or-nothing and requires way more monitoring and adjustment than a set-it-and-forget-it auto climate system should.
Any others here with similar issue?
