Micho523
- Jaime
- Aug 26, 2023
- 1
- 204
- 202
- Atlantic Beach FL
- 2023 Lariat 502a
- Engineer
In forscan, on your SCCM, perform a write all. It will tell you nothing has changed and ask if you want to force. Press yes. Had to do this myself yesterday to clear a button mismatch code.I'm at wits end. Whoever can solve my problem I'll send you $20 on Venmo or cash app as a thank you. I’m pretty experienced with Forscan and have never had an issue getting anything to work before.
Truck: 2021 F150 SCREW Lariat 500A. Max Tow Package & 360 Cameras
Installed:
-WPT-404-Wire Assembly
-W721079-S437 Steering Wheel Bolt
-ML3Z-3F791-BB Steering Column Tube. This includes the new clock spring. Is this my issue?
-ML3Z-3600-RA Steering Wheel
Notes:
-Properly grounded WPT-404 and tapped into fuse 29. I know it has power because fuse 29 turns on the screen. When I remove the tap and fuse, the screen doesn't turn on telling me the new wheel has power.
-All connectors have a female home and those female sides have pins. They aren’t dummy female connectors.
-Saved the stock SCCM, IPC, APIM and HVAC modules on Forscan before proceeding. I have other mods added way before I installed the HSW like the Unreal UI, Global windows, etc…
-Did not load any saved profiles to allow forscan to search for each module
-I don’t have functionality of the left buttons on my steering wheel. In past posts that has been because users didn’t write the stock SCCM module onto the new parts. I have added the stock SCCM module many times and it doesn’t fix the problem.
Attachments are photos of the stock and modified modules.
The spreadsheet shows the changes made between the stock vs modified modules. If you see Os instead of 0s, it’s because excel doesn’t like 0s in front of numbers or letters. You can confirm the codes are correct with the screenshots.
Let me know what you guys find out and I’ll gladly pay the person who can tell me why this doesn’t work.
