Actually working on brightening DRL's today. Looks like I have to change that in the "as built" section. Just saw what line and code I need to change. I also have my front turns as DRL's with LED bar. Looks sweet!So you applied changes to brighten your DRL's and parking lights. What did you do to your turn signals? I also have Bambi mode and double honk disabled.
Can you get a pic, would like to see how that looks?. I also have my front turns as DRL's with LED bar. Looks sweet!
What EXACTLY did you change for "DRLs at full brightness, BCM"?Double honk disable, BCM
Fog light cornering disable, BCM
Enable digital numbers under engine and tranny temp gauges, IPC
Front seatbelt chimes disable, IPC
Door ajar chime disable, IPC
Turn signal lane change tap count to 4, SCCM
Disable windshield anti fogging strategy so recirc stays on, HVAC
Enable front cams with tire tracks in mud/snow mode, IPMA
Glare Free headlights, APIM, IPMA, SCCM, IPC, HCM
Headlamp switch remember position, BCM
Battery target charge state to 95%, BCM
Lots of discussion here:What EXACTLY did you change for "DRLs at full brightness, BCM"?
Well, where are you?I just want someone near me to help me out. The main thing i want off is that DANG double honk.
Where are you hung up? This is an easy one to do. It's under the "BCM". Go to Double Honk, then click disable.Well, where are you?
Ah, dang. Well, I’m around 3,000 miles away from you, but feel free to swing by anytime and I’ll Forscan your truck for youCentral Florida.
<SNIP>
<SNIP>
