3DogKnight
Does anyone else other than myself have the dome light not come on when the door is opened? The light comes on with the overhead switches but not the door. 2021 XLT 302a
If this is something that just started to occur 'for no reason', your 12v battery bus voltage is low. Ford won't actually put a proper charging voltage on the system. It instead trickle charges the 12v batteries at 12.85v.Does anyone else other than myself have the dome light not come on when the door is opened? The light comes on with the overhead switches but not the door. 2021 XLT 302a
Good luck reading the icons on those buttons.There is an interior light defeat switch in the switch console on the headliner (for most models). This prevents interior lights from coming on when the door(s) are opened.
Agreed. I’d just look for anything that’s lit yellow, all the light buttons should be lit blue if you want the interior lights on when the doors open.Good luck reading the icons on those buttons.
Thanks BLoflin. I found the switch on the console and the dome light works now. For some reason I thought this yellow light was not a switch. It's a good thing I'm not a rocket surgeon.There is an interior light defeat switch in the switch console on the headliner (for most models). This prevents interior lights from coming on when the door(s) are opened.
Thanks for pointing out the yellow light. I thought that was a permanent light for something and not a switch.Agreed. I’d just look for anything that’s lit yellow, all the light buttons should be lit blue if you want the interior lights on when the doors open.
