Pedaldude
Parasitic drain testing is one of the most hates diagnostics for this reason. My Lincoln likes to go through batteries a bit more than the average car, it’s a 2001 and the modules that go to sleep take exactly 45 min. and to see which one is creating the drain, you isolate the modules, taking out one fuse at a time. Certain ones are known to be more at issue than others but to be thorough, you can’t make assumptions. Long story short, I spent a whole 12 hours over one night, working a few minutes at a time and also had to trick the door to think it was shut. Then just to be thorough, you need to check to make sure that something isn’t randomly waking up long after they originally went to sleep. The truck used a fair amount of juice but was 100 percent in spec. but I had to go through the whole rigamarole to eliminate it as a problem. I really don’t know why, especially a 2001 truck needs to have certain modules to be draining the battery for 45 minutes but if it behaves just fine turning on after a night sitting, why can’t it go off after 5 minutes instead of draining the battery needlessly for five times that duration?Truck has been at the dealer for two days. Parasitic drain of 3A! Everytime they make a change it takes 75mins to redo the module sleep test...
On these modern vehicles, where they’re connected wirelessly and there’s multiple programmable computers all connected, I can’t see why a parasitic drain can even happen, unless it was just sloppy programming and design. 75 minutes is preposterous and while an AGM battery is slightly better than a FLA, it’s not going to prevent damage after multiple deep cycles, there also needs to be some kind of storage mode for when you don’t want all the modules cycled and reset when the battery is disconnected, either for service or long term storage/parking...the worst I ever saw was a Hyundai Genesis that had to be towed to the dealer for reprogramming because the air suspension wouldn’t function after collision repair necessitated disconnecting the battery. It had to be jacked up with floor jacks just to get it off the hydraulic lift.
Mercedes just had to contract a technology company to make third party repairs on their cars at dealerships because they made them so complicated that they can’t figure out how to fix their own cars.
There really needs to be a fail-safe system when it comes to all the technology in modern vehicles. Something that can be an inconvenience to some could prove deadly in an emergency or remote area.
