staying_tuned
I wanted to go with a classic 5 or 6 spoke design, I began hunting before I purchased the truck. I ended up reaching out to JD @BRINK WHEELS to learn more about these Fangs. I opted for the +18 offset to offer a bit more of an aggressive stance without having to worry about the sides getting thrashed. He was able to give me a great deal on a full set of 5. If you're interested in any of their wheels I'd highly recommend you contact JD directly. I essentially got 5 wheels for less than the price of what is published for 4. I've had great experiences with Cooper tires and noticed they offered their Rugged Trek in an SL at 275/60R20.
I wanted something light yet capable off-road. My vortech centri kit is on the way and I don't want to hamper performance with excessively heavy wheels and large tires. I hope to run mid 11s. I plan to document that install, all fueling and tuning components are here, I'm just waiting on the V3-Si based kit in black from Vortech. It should be here by the 20th. 5 Star is on deck for tuning with Terry @beefcake supporting the build on the hard-parts & logistics side. His 22' Vortech F150 is bonkers, for sure check out what they are up to if in the market for a centri based solution.
I had the tires mounted, balanced and then had the truck aligned given the drop shackle addition and slight offset change. 5 new TPMS sensors programmed for the set and I was on my way. These Rugged Treks ride great. They are at 35psi, as were the stockers. The only change I've noticed is an ever so slight increase in stiffness, not annoying in any way and also offers less roll when cornering. I doubt I have the same dry grip as the dynapros but these are more planted during spirited turns. Noise is very minimal, a very slight hum can be heard with the radio off. Volume-wise they remind me of the Toyo O/C AT3, also very quiet for a mildly aggressive A/T.
Weight Difference:
Old: Factory 20" 20x8.5 wheels w/ factory 275/60R20 Dynapro AT2: 80.1 lbs
New: Brink Venom 20x9 wheels with 275/60R20 Cooper Disco RT: 78.9 lbs
Not a ton of weight savings but any is good so I'll take it. Here are a few shots. I had posted a close-up of the finish when I received the wheels back on my build thread.
Weight Difference:
