Jesse-Infotainment
Config is wrong. Do you have forscan Or FDRS?1FTFW1ED7MFB09021
No I don't have thoseConfig is wrong. Do you have forscan Or FDRS?
Ok, well youll have to convince your dealer to PMI the GATEWAY somehow. They will probably not do it. Until that happens you wont have BlueCruiseNo I don't have those
Okay. Thanks for the info.Ok, well youll have to convince your dealer to PMI the GATEWAY somehow. They will probably not do it. Until that happens you wont have BlueCruise
If youre able to make them tell them when asked if the Original Module is installed they need to select NO!Okay. Thanks for the info.
The most frustrating part is that it takes so little effort to do this and the customer drives away with the truck fixed.Ok, well youll have to convince your dealer to PMI the GATEWAY somehow. They will probably not do it. Until that happens you wont have BlueCruise
2.8.1Hi Mike, 22087 Rev421
Its stupid. But its one way to do it.
After thinking it wont fix it. Im about 95% sure also youll have a Odometer statement on your truck now since its federally mandated Im sure that will help resale
Jesse,Jesse,
It appears that I am at 2.8.3 which I got OTA. I think the dealership screwed something up because still no BC. Can you take a look for me when u get a chance. VIN 1FTFW1ED7MFB59479? Thanks
I’m in Arlington.
send me your vin I want to see what they have done
If you need help getting BC to work I see your issue. Would take a few mins to fix it with Forscan.Could u help me out?
1ftfw1ed6mfa99212
Just to assist Jesse in assisting you....I messaged you. Im not 100% sure i have what i need to fix it but would be willing to order forscan and licensing
Windows laptop
Forscan is free download at Forscan.org
Depending on what functions Jesse will need to use, it's free to download.
And you will need an OBD adapter that works with Forscan.
OBDLink EX (USB interface) is a fast safe example
