tony72cutlass's'
AHPorosity in the surface, as in poorly machined. Not thin.
Its a block porosity problem. That starts on day 1?I haven’t even seen or heard of this leak, I doubt it affects many engines at all. Unless you have oil drops all over your driveway I wouldn’t get your panties in a bunch. It would be leaking from day 1 since what they describe in this TSB would have been a poorly machined mounting surface. This kind of leak starts on day 1, not over time.
YesIts a block porosity problem. That starts on day 1?
Maybe heat cycling opens up that gap? I assume there is no gasket between the oil housing and the block, it's just machined fit? or maybe o-ringed?I'm confused. If Its a block porosity problem, and the leak starts early or "day 1", then would these issues not have been caught before the vehicle left the factory?
If It is something that surfaces over time, then we might have potential issues creep up later.
SOOOOOOO, When does the issue arise? Early or over time? I'm reading two different stories.
those are very good questions.Maybe heat cycling opens up that gap? I assume there is no gasket between the oil housing and the block, it's just machined fit? or maybe o-ringed?
I dunno, I'm not upset yet. I think it's good ford is offering a warranty repair/acknowledgment. Hopefully this isn't hugely widespread.those are very good questions.
I haven't had this truck but a week, and now this............. Should I have kept my 23 Ram (its got its own issues).
Well, they did identify the "timeframes" of manufacture that could be affected, AND the area that might have issues.I dunno, I'm not upset yet. I think it's good ford is offering a warranty repair/acknowledgment. Hopefully this isn't hugely widespread.
Yes but does that mean EVERY engine is bad in that timeframe, or it could be affected? I think it's the latter in this case.Well, they did identify the "timeframes" of manufacture that could be affected, AND the area that might have issues.
Well, being as they identified a range of dates, I'd say all the blocks during that time frame were probably made in the same plant, and somehow the imperfection in the manufacturing process was identified to those dates.Yes but does that mean EVERY engine is bad in that timeframe, or it could be affected? I think it's the latter in this case.
yes either a QA process was skipped or some other detail in the casting process was missed or not considered, so that's probably whats up with the range where something could happen. Guess we'll have to see over the course of time. I'll be buying a factory ESP before my b2b ends. Even if I never have the issue.Well, being as they identified a range of dates, I'd say all the blocks during that time frame were probably made in the same plant, and somehow the imperfection in the manufacturing process was identified to those dates.
