Aica0177
Hello ! Anybody knows the part number for the mirrors? I need with blind spot, puddle light and spot light (which already have all them) just looking to add the power folding. Thank you in advance.
After working through this for the past couple of months, I went with the OEM parts because I'm not that great on the cut and splice thing. Although it was more expensive, it was really simple/plug and play. The hard part was getting my hand inside the driver and passenger side doors to disconnect and connect the new wires. I purchased the Ford mirror package with the new extend switch and face plate ML3Z 17696 DA. I had an issue with the switch that came with it as it didn't work once programmed. I had to run down a new switch, and they were back ordered from Ford. Switch is a cheap part at around $10, but hard to find. Found a new one on eBay (Ford OEM). I opted for the Ford OEM Platinum driver and passenger wire harness. Driver: ML3Z-14631-H-1X and the passenger side: ML3Z-14630-H-1X. I also had the dealer program the new mirror functions. My 2021 Lariat had power mirrors, so most of the functions were already there. Only thing I needed was the power extend option. Hope this helps!Hello ! Anybody knows the part number for the mirrors? I need with blind spot, puddle light and spot light (which already have all them) just looking to add the power folding. Thank you in advance.
Did you just swap the whole doors harness? One of the other comments I read I think it said something about pulling the wires out.After working through this for the past couple of months, I went with the OEM parts because I'm not that great on the cut and splice thing. Although it was more expensive, it was really simple/plug and play. The hard part was getting my hand inside the driver and passenger side doors to disconnect and connect the new wires. I purchased the Ford mirror package with the new extend switch and face plate ML3Z 17696 DA. I had an issue with the switch that came with it as it didn't work once programmed. I had to run down a new switch, and they were back ordered from Ford. Switch is a cheap part at around $10, but hard to find. Found a new one on eBay (Ford OEM). I opted for the Ford OEM Platinum driver and passenger wire harness. Driver: ML3Z-14631-H-1X and the passenger side: ML3Z-14630-H-1X. I also had the dealer program the new mirror functions. My 2021 Lariat had power mirrors, so most of the functions were already there. Only thing I needed was the power extend option. Hope this helps!
I’m having the same issue. Installed Power fold tow mirrors on my 23 XLT and they move just a tiny bit when you press the fold button. I thought I had everything correct in forscan but I’m guessing there’s something I need to change and I don’t see any option for “tow mirror fold” specifically. Can you shed some light on this? I spent a couple hours last night getting the mirrors to the point where they were parked and not loose anymore and I just want this power fold to work right nowGot it fixed. I had “tow mirror fold enabled and once it disabled it and got it written. Boom it worked
