itsDom
Hi everybody,
I own a 2022 F-150 Powerboost hybrid with 4x4 and Max Trailer tow. The truck does not have CCD and no FX4.
When I got the truck, I knew I wanted to lift the front with some puck spacers (not actually pucks, I just forget what brand I purchased) to remove the factory rake for when I'm just cruising around town. It lifted the front of the truck about 2" over factory. It looks great and doesn't cause any noticeable loss in MPG - God bless the Powerboost.
I also tow a couple different types of trailers quite frequently and the truck would squat quite a bit, which isn't safe and defeats the point of having a levelled truck. So, I outfitted some AirLift Load Master 5000 airbags with the onboard compressor to help level out the truck while towing. I love it! It works great and I love the versatility that the airbags provide. My plan was to always put the airbags on, as I thought being able to run the airbags at 5 psi while just cruising around would preserve the factory ride quality. However, that hasn't been the case.
My concern now is that the ride quality is quite harsh. While driving around it just feels like I am getting catapulted around in the cab. It's worse when you sit in the back. My father has literally the exact same truck as me (totally stock) and the difference is night and day. I had a 2021 XLT with the same level kit installed and the ride quality was the same as factory, which is why I think my problem lies with the rear suspension/airbag set up.
I think I would be able to eliminate most of my ride quality woes with a rear shock upgrade. I have been looking at the Bilsten 4600's or 5100's and with the research that I've done I'm even more confused about which shock would best suit my application.. I don't know too much about these shocks, or any shocks actually.
If anyone would be able to chime in with their suggestions, it would be greatly appreciated as I don't really have the time to make a mistake and order the wrong shocks..
Thanks in advance!
Thanks in advance!
